Previous in Forum: How To Design Plug For Tube Heat Exchanger   Next in Forum: How Many Online Methods to Detect Tubes Leakge in Condenser?
Hydraulic Oil
01/12/2012 12:39 AM
Sir,
I have a 200 Ltr drum of hydraulic oil (Servo VG-68 ) since last 2 years & i have a need to fill it in my molding m/c, can it be use. It was brand new that time, if no....please define.
Thanks
Good Answers: 53
Re: hydraulic oil
01/12/2012 1:27 AM
I think it's going to work fine,But my suggestion is don't go by my words. best way is to ask the manufacture or look on the manufacture packaging exp Date if there is any.
Its not good to put your RS20000.00 on bet against a RS2.00 Phone call or a 50paisa email to company.
Re: Hydraulic Oil
01/13/2012 9:15 AM
Normally hydraulic oil do not get deriorated in 2 years of storage if contamination is not there. Depending on the storage of container, if any thing has entered in the oil, it should be made good by centrifuge and filtering.
Suggestion to confirm from manufacturer is still valid and really do not cost much.
Re: Hydraulic Oil
01/13/2012 11:05 AM
Dear Mr. Gaurav,
If the seals are not opened and intact, the hydraulic oil can be used.
However pl. consult the Manufacturer/his Authorized Agent.
DHAYANANDHAN.S
Re: Hydraulic Oil
04/01/2012 5:04 AM
The used hydraulic oil could bee purified by a vacuum filtration machine, remove the water and gas,impurities. They do this for couple of years.
Find more on
http://oilfiltrationman.weebly.com
http://pureyouroil.diytrade.com
http://oilpure.wordpress.com
http://oilfiltrationman.blog.com
Register to Reply 4 comments
dhayanandhan (1); Mukesh0861 (1); oilpure (1); rakesh_semwal (1)
