Previous in Forum: Flow Meter Configuration   Next in Forum: Relay Contact
Square Root
01/12/2012 2:40 PM
what is square root function in flow meter?why it is using?
Thanks.
Re: square root
01/12/2012 2:51 PM
Re: Square Root
01/12/2012 3:07 PM
Maybe I should have added DO YOUR OWN HOMEWORK.
Re: Square Root
01/12/2012 4:41 PM
Q = k √(ΔP)
Re: Square Root
01/13/2012 3:55 AM
Nope. It's the square root function in a differential pressure transmitter that is in the spotlight. Differential pressure across an orifice is so 1973...
Re: Square Root
01/13/2012 8:24 AM
That's me.
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
Re: Square Root
01/14/2012 11:13 AM
The amount of differential pressure (DP) generated by an orifice or venturi is proportional to the square of the fluid flow rate. 2x flow results in 4x DP ; 3x flow results in 9x DP. In order to "linearize" this pressure measurement and get a signal representing the flow rate, you must square-root that pressure measurement.
For more detail, read the section in the online e-book called "Flow Measurement from Differential Pressure".
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
Register to Reply 6 comments
lyn (3); PWSlack (1); tonykuphaldt (1); Tornado (1)
