Previous in Forum: Need a Latching Relay at No Power   Next in Forum: Calculation of Overhead Line Conductor
8 comments
PLCC and OP_GW Communication
01/18/2012 4:23 AM
Hi,
Regarding PLCC and Optical fiber ground wire communication through transmission lines, I have read that PLCC provides single channel communication while optical fiber provides multi channel as well........and bandwith provided by optical fiber is much larger. Apart from the fact that optical - fiber is much costly.........are there any other advantages for power line communication system?
Regards,
sks
Re: PLCC and OP_GW communication.
01/18/2012 4:30 AM
The main advantages are complete immunity to electrical interference and the ability to put potentially millions of channels of information down one fibre.
01/18/2012 4:49 AM
(Q1) one channel means ' a single wave of particular wavelength transmission' through an single optical fibre??
(Q2) Also, modular and demodulator are used for analog transmission and multiplexer and demultiplexer are used for digital transmisison??
(Q3) Amplitude modulation and frequency modulation are used for analog transmission. What type of digital modulaiton used for digital transmission??
Regards,
sks
01/18/2012 5:06 AM
Go to the Wikipedia articles on optical fibre and start there [Wikipedia is down today].
Engineering Fields - Petroleum Engineering - Rig Electrician United States - Member - the Oil Patch Engineering Fields - Power Engineering - Drives & Gen's Engineering Fields - Instrumentation Engineering - Drive Control Popular Science - Cosmology -
01/18/2012 12:19 PM
GA Slack, if the OP has ANY inverters it's double advantage
Why do they make manhole covers round? so they won't fall in [before asking "Who is John Galt?"]
Good Answers: 102
01/19/2012 7:33 AM
That is true for optical transmissiion but is not what the OP asked mate.
OP wanted to know what advantages powerline carrier communications has over a discrete fibre route apart from the cost saving of not having to run the fibre.
Re: PLCC and OP_GW Communication
01/19/2012 5:49 AM
SSB -Single Sideband Propagation(broadcasting) DSB- Double Sideband Propagation(communication) Study about bandwith !
01/20/2012 1:00 AM
thanks anonymous........
i know that fibre optic has a much higher bandwidth than PLCC. I am asking this question to know if communication between hydropower plant and substation can also be done through fibre optic. I found in my studies that though optic fibre has been used in SCADA and OP-GW in an already built hydropower plant of my study, it is not used for hydropower plant to substation communication. For this communication, still PLCC is used - for the powerplant which used optical fibre for SCADA and OP-GW. Why this? Can't optical fibre be used there as well?
Regards,
sks
01/24/2012 3:59 AM
If fibre cable can be of safe instlallation on that site , vey well - could be used for monitering . Propagation delay , cable resistance at times - we may consider for Quick reaction .
Register to Reply 8 comments
Anonymous Poster (1); kwcharlie (1); PWSlack (2); sauravbabu (2); sivaa (1); Wal (1)
