Previous in Forum: Communication   Next in Forum: Control Valve
17 comments
Binocular Repairs
01/24/2012 5:46 PM
My friend brought some old NIKON 10 x 70 6.5° FOV binoculars to my lab asking if I could clean the main objective lenses. I have had some experience working on optical devices and have some special tools like spanners for removing lens retaining rings but before touching them I did as much Internet surfing as possible reading all about these binoculars. I found out that they are very good ones and highly coveted by the astronomical community.
The inside of both objectives have circular marks and it looks as though somebody tried cleaning them from the porro prism end. Since these glasses are supposed to be nitrogen filled and hence sealed I assumed that the seal was broken long ago so any attempt I made would have no negative effect on this seal.
Using my special optical spanner I easily removed the first outer cosmetic cover ring from both lenses. This exposed the two collimating rings which are used to make tiny movements of each objective during the collimation proceedure. From what I have read the outer ring holds the lens in its cell and the inner ring must be turned for the collimation to be performed. Both of these rings were EXTREMELY tight and I was unable to loosen them without using excessive force. I also tried grasping the outer shell hoping to remove the entire lens cell intact from the body of the binoculars. I used a belt type wrench and my helper held the binoculars at the edge of a padded table. Again, the forces required made me halt.
Have any of you had any experience with this particular binocular? Knowing the quality of these binoculars I want to proceed with the utmost of care since they still work and in spite of the scratches the view of the night sky is still spectacular.
Regards
John
Re: Binocular Repairs
01/24/2012 6:00 PM
Without a picture of how the lenses are assembled, I'm not sure why you would want to remove the retaining rings. You can clean the outside lens surfaces without disassembling the lenses. If the inner surfaces have gotten dirty, most binoculars I've owned allow you to remove (unscrew) the lens cells as whole units to clean the inside surfaces. [Are these not like that?] You might need to unscrew the lens barrels from the central prism section, then use long swabs to clean the inner surfaces.
Separating an achromat lens set is usually only necessary if a contaminant has somehow gotten in between the lenses. If you don't get the lenses aligned properly and get the cell gap correct when you re-assemble them, the lens assembly can give you chromatic aberration.
If you can post a photo it might help.
01/24/2012 6:54 PM
The dirt appears to be on the inside of the objectives. I dont think it is between the individual lenses. I would not want to disassemble down that far either. There are no unscrewable barrels. The entire body is one single casting. Thats why I think somebody tried what you said using VERY long swabs all the way from the other end where the back plate can be removed to gain access to the prisms. I cant seem to loosen the lens cell as you suggested. I´ll try to send you a foto.
Thanks
John
01/24/2012 6:07 PM
Use the classic mechanic's trick.
Cool the lens assembly and heat the tube.
Maybe an ice cube and a heat gun?
01/24/2012 7:58 PM
Interesting suggestion. It might work as long as I dont get the lens assembly wet.
Thanks
John
01/24/2012 8:23 PM
Take a look at the thermal expansion properties of the metals of construction and do the math. Do the math on the glass too.
I think you are capable of performing this if you choose to try it.
01/25/2012 8:40 AM
The difficulty of shipping into and out of this country are also an additional motive so I think I might try it. Without doing too much math I´m sure the body, made of aluminum, and the glass lens have considerably different expansion coeeficients as you suggest so maybe a very cold damp cloth on the lens part and a hot cloth on the body would work. What I need is a copper clampping wrench with a diameter of 3.54 inches to grab the outer body of the lens cell without marring it. I searched a lot but can only find these wrenches in smaller sizes. Maybe an oil filter wrench might work. I do not want to cause any damage to these beautiful babys.
We were hoping to use these glasses to view Comet Garradd this weekend from a dark mountainous area towards the center of the island about 1000 meters above sea level so I think I will try the disassembly when we come back.
Thanks for all your input. I will let you know how it works out.
Regards
John
Good Answers: 58
01/26/2012 8:24 AM
It sounds as though you could use a strap wrench like the type used to remove oil filters. Sears sells a plastic strap wrench that is non-marring.
01/26/2012 11:21 AM
If you check around, you might be able to find someone who has a Vortex Cooler. They are made by companies like VorTec and ExAir. They use compressed air as an input, and output cold air at one port and hot air at the other. With some flexible tubing, you could direct the two streams to the appropriate places, or just point the cold air port at the lens and use a heat gun on the barrel.
Machinists sometimes use them to cool cutters where they don't want contamination of a part by liquid coolants. The ones I've used are noisy and use a lot of compressed air, but they do work. I see them advertised for cabinet cooling, which tells me they must have found ways to make them quieter.
01/24/2012 6:17 PM
I'll ask/suggest the obvious -- have you checked with Nikon? They might not formally offer disassembly/repair instructions to "unauthorized" technicians, but a call to tech support, or engineering may find you a helpful "authorized" tech/engineer.
01/24/2012 7:33 PM
Yes, I sent them a request for information and am now waiting to see what happens. Most large companies like Nikon dont usually respond to little questions very well. I was hoping one of you guys might have had an experience with this very same model.
Thanks
John
01/24/2012 6:45 PM
This is a source for the shop manuals and a support site....
http://www.fixya.com/support/nikon/binoculars
01/24/2012 7:29 PM
After some further research, these are worth at least $800, any advice I could get was to get them factory serviced....est $65 + $20 for realignment + shipping
01/24/2012 7:40 PM
yes you are probably right.
I have been able to do some pretty complicated fixes in the past successfully and so all my freinds bring me thier things first for my opinion. In this country we still fix a lot of things that others up north throw away.
But I think you are right on this one since they are still quite usable as is it would be a shame to damage them.
John
01/24/2012 7:35 PM
Thanks
Good Answers: 56
01/26/2012 12:52 AM
There is a large Internet community of optical enthusiasts at the web site called Cloudy Nights. Many are professionals and there is a dedicated section devoted exclusively to Binoculars section of the Forum.
Membership is free.
Here is the link directly past the home page to the Binocular Group.
http://www.cloudynights.com/ubbthreads/postlist.php/Cat/0/Board/binoculars
Should you choose to join so you can post questions, return to the home page and simply apply. They are a generous group. You'll get lots of experienced help.
Laughing Jaguar
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
Good Answers: 179
01/26/2012 8:27 AM
If you do ship them out to a Nikon Service Center make sure you have enough shipping insurance to cover their replacement because of theft, loss and damages! At $800 USD those are very expensive binoculars indeed!
Good luck with them!!!!!
Hobbies - Fishing - Popular Science - Paleontology - New Member
Good Answers: 27
01/26/2012 9:44 AM
Chances are the objective lens retaining rings are sealed. Kern and Zeiss military binocs use a tar like substance which is softened through ultrasonic immersion in freon. Applying heat also works in certain conditions but I would highly advise against it.
To properly apply nitrogen it's advisable to use a vacuum chamber capable of -10 atmospheres.
Prophet Freddy has the answer!
Register to Reply 17 comments
CaptMoosie (1); dkwarner (1); Duckinthepond (1); JOHN H VAN ALLEN (6); Laughing Jaguar (1); lyn (2); pantaz (1); SolarEagle (2); Usbport (1); welderman (1)
