1) inflow at ground level - construct an earthen dam in a water course (150m across x 150 fetch x 2m deep will store about 10000 m3.) The water will get soiled and polluted and may need treatment or clearing before use. and some will be lost due to evaporation.
2) outlet at ground level - Construct a covered circular reservoir (50m dia x 2.5 deep)
and fill with clean water - check quality before use.
3) each household can store water from the roof of the dwelling in tanks.
The water can get contaminated (bird droppings , dust , acid rain etc) and the quality should be monitored)
You need to calculate the requirements carefully.
In SA the minimum is set by legislation at 6 m3 per household per month. (at least 30 - 100 m3 per household in 5 months.)
we can stroe the rain water at roof top of every house, can we find out some cheapeset and technical sustainable way to do it?
or
the small reservers is anouther option likely with the capacity of 1 or 2 million liters
but the question is:
the store water (not moving/floting for long time) get infected and bacteria can develope in to this, How we can save and make it pure for long time technicaly?
we have to charge some chemical or O2 to make it fress?
