Previous in Forum: Which Type of Mass Flow Meter Should I Buy?   Next in Forum: Mechanical Engineering
18 comments
FRP Manufacturing Procedure
01/27/2012 11:20 PM
Hello
Can in one please give the details that how the FRP storage tank is manufacture?
We have placed the order of FRP storage tank of specs 3300mm internal dia,10mm thickness ,height 2500mm, water resistant resin.
Above all the nozzle attachment is of SS material?So is it possible that any SS nozzle
can be attach with the FRP shell?If yes that how these SS nozzle is going to attach with FRP tank shell?
Re: FRP manufacturing procedure
01/28/2012 12:35 AM
Please search the term "tank adapters". They are made of various materials, including stainless.
Re: FRP Manufacturing Procedure
01/28/2012 3:17 AM
Having already placed an order, the best source of information will be the organisation with which the order has been placed.
01/28/2012 6:02 AM
Does this mean that you finished those two projects you were working on and have a degree and a job?
Anyway, the fittings can be molded-in-place. Or, maybe they will use bulkhead fittings.
Let us know how they did it when you get your new tank.
01/29/2012 12:40 PM
Yes I am working as a proect engineer in project,since this is my first project as I have recently graduated, so that is why ia a bit concerned abaout it.
ok i will let you know
01/29/2012 12:44 PM
Fair enough. Do you understand how FRP tanks are made?
02/09/2012 12:26 AM
they told me that they will cover the nozzel SS pipe with the frp coating and then will attach it with the the FRP shell.So do you think it would be appropriate?
02/09/2012 12:46 AM
Please read (or reread) posts 6 and 11. I would get a tank adapter as shown in post 6, made from stainless to match the further piping as said in post 11. I don't see the purpose for additional FRP cladding of the tank/header, although this additional step could give flatter surfaces for gasket sealing.
01/29/2012 2:13 AM
There are books and websites such as http://www.designtanks.com/Pages/Default.aspx
and others...
01/29/2012 12:13 PM
thanks for the link,it was indeed very informative
01/29/2012 5:05 AM
You have already placed order for the tank with SS nozel and the organisation who has accepted the order can give best details of manufacturing of the Tank. Yes it is possible to give SS nozels on FRP tanks.
Good Answers: 102
01/29/2012 5:51 AM
Holesaw and bulkhead fittings.
02/06/2012 11:22 PM
May be this question sounds very odd for you people.what should be the material of nozzle on FRP storage tank?would it be good to have SS nozzle or FRP nozzle?
02/06/2012 11:40 PM
This is not an absolute rule, but I would tend to select a tank adapter (bulkhead fitting, possible other terms) of the same material as the further piping.
Good Answers: 102
02/07/2012 4:01 AM
FRP nozzle? Maybe PVC if it is nonmetallic.
02/07/2012 8:51 AM
The nozzle will be going to connect with the metallic piping
Good Answers: 102
02/07/2012 9:51 PM
WRT #11.....
Is your piping copper, brass, stainless, iron, titanium.......lead, or plutonium?
At the point in the FRP tank shell where you want to install a nozzle you may have to cast a stiffener into the substrate to provide a sturdy anchor point for the plumbing.
If your tank has a curved surface at these points you will also need to cast in a flat surface zone to permit proper seating for a bulkhead nipple and its retaining nut ie inside and outside.
I figured this tank should have been built and commissioned by now. What's taking so long?
02/07/2012 11:53 PM
SS piping, well there are 6 nozzles are going to be fit, 3 on the top(flat) and 3 there are going to be fit around the shell. My vendor told me that he will fit these nozzle by cladding on frp.
02/13/2012 12:03 PM
That link was very helpful. Thanks for posting it.
Register to Reply 18 comments
lyn (2); Mukesh0861 (1); PWSlack (1); SHARIQABBAS (6); stargan (1); Tornado (3); Wal (3); YesICrane (1)
