Previous in Forum: Running a 60Hz 525V Motor on 50Hz Supply   Next in Forum: Sodium Lamps
Electrical Specialist
01/30/2012 3:21 AM
If high voltage generator tells u (ie. indicate) ...generator stator winding Earth faults .. where should i start grab my meter???? whats wrong with it???..bcos i can not synchronize machine.
Re: electrical specialist
01/30/2012 4:13 AM
Look for ohms between the stator wiring and Earth. Isolate the supply first, though.
Reply Score 1 for Off Topic
01/30/2012 5:13 AM
done and itb seems to be okey
01/30/2012 5:42 AM
Isolate the wiring connected to it and check that too. Why wait for a reply via CR4 (rhetorical question)?
Location: off the beaten track, not quite whoop whoop nor humptydoo
Re: Electrical Specialist
01/30/2012 5:32 PM
maybe use a megger...?
Everything works out in the end, just not neccessarily how you want
Good Answers: 181
01/30/2012 6:58 PM
U c%d try 2 uz a transl8r az weL.
Anonymous Poster (1); Chook (1); PWSlack (2); TonyS (1)
