Previous in Forum: Centrifugal Pump Impeller Size   Next in Forum: Precision Food Cutting Machinery
11 comments
Flow control
02/01/2012 12:02 PM
Hello everyone,
I am working on a hobby project and I have two flow streams. I need that the flow in srteam 1 be a percentage of the flow in stream 2. I am looking for some exquipment or a set-up that would make this possible.
Any help/ideas would be appreciated.
Re: Flow control
02/01/2012 12:23 PM
Flowrates? Material in the streams? Open channel or pipe? Temperatures? Pressures? Materials of construction of the conduits?
Re: Flow control
02/01/2012 12:59 PM
Great
When you feel like you want to provide us some specific details on this project or you run into a specific difficulty on this project, tell us what you'd like us to discuss. This sounds like an interesting project.
Re: Flow control
02/01/2012 2:08 PM
F1 =oil, 10GPM, 150F, 175 SSU viscosity, SST pipe
F2 = water, F1*14%, ambient temp, 20psi, teflon hose
Thank you in advance !
Re: Flow control
02/01/2012 4:41 PM
What you are looking for is called a flow ratio controller. and is a standard function of many process controllers.
Googling "flow ratio controller" should get you a selection.
Good Answers: 21
Re: Flow control
02/02/2012 2:51 AM
Assuming:
1. the pressure in both streams is equal and constant,
2. the hoses for each stream are of similar diameter,
3. your "ambient" does not vary too much , and
4. there is no need to monitor, or change the ratio value once set....
You might get away with installing a restriction orifice at F2 . Try pipeflowcalculations.com
Good Answers: 21
Re: Flow control
02/02/2012 3:57 AM
Correction: You might get away with installing a restriction orifice at F1
Good Answers: 102
Re: Flow control
02/02/2012 1:44 AM
Mixing oil and water at 10GPM......
Interesting hobby you have there. Tell us more about the end use of the colloid.
Re: Flow control
02/02/2012 5:52 AM
Mayonnaise?
Good Answers: 102
Re: Flow control
02/02/2012 4:10 AM
Some sort of venturi arrangement springs to mind.
I'm assuming that the two are combined. They may not be. They could have independent destinations and just require proportional delivery.
More info please AKUR. Coming up with solutions in open loop mode is tough.
Re: Flow control
02/02/2012 5:52 AM
Another possibility is a peristaltic pump with two drives: speed ratio between the two, or two differently-sized hoses driven by one roller-shaft.
Good Answers: 27
Re: Flow control
02/02/2012 8:01 AM
A properly sized pitot tube may suffice your need ...
vsar
Register to Reply 11 comments
AKUR (1); DaveR (1); Hilton (2); PWSlack (3); redfred (1); vsar (1); Wal (2)
