Previous in Forum: DG   Next in Forum: Electricity Sector in India
Synchronization Problem
02/07/2012 2:18 AM
I gatta one problem during machine synchronization, at normal operation no incoming( generator voltage) but when we put generator breaker , things change we get incomming but we can not see busbar voltage /running voltage ( dat means meter never be defective at all).so could someone suggest what hero is going on with the system??????
Re: synchronization problem
02/07/2012 5:32 AM
Has/have the incomer circuit protective device(s) operated?
02/07/2012 6:27 AM
I do not see very well what kind of machine you are talking about! is it a motor? a generator? or is it assembled to work in both regimes?
“For no man can forbid the spark nor tell whence it may come.” ? Francis Bacon
Re: Synchronization Problem
02/08/2012 1:16 AM
Unclear data...
with your current data.. I believe u need to check ur PT and CT...
Frank - Catch my statement if you can.
Good Answers: 102
02/08/2012 5:43 AM
Describe the situation and problem again. Defective meter?
05/15/2012 8:50 AM
what you means is generator is good conditon! so want is just to see the output voltage is that right , i suggest you to check the volt meter terminal it maybe one of the terminal wire is disconnected or if not replace new one !!!
i want ot helf piple need assistance and to share my knowleged in technical
electronick (1); frankcorners (1); PWSlack (1); toink (1); Wal (1)
