Previous in Forum: AC Motor Testing- Meter Showing Fluctuating Current   Next in Forum: Synchronization Problem
DG
02/07/2012 2:14 AM
my load is 700 amps,what capacity of dg set required for that
Re: DG
02/07/2012 3:04 AM
700 amps; how could it be anything else?.
How many volts? (Then we can calculate kw.)
Re: DG
02/07/2012 3:22 AM
Yep. Something over 700 amps will do it.
Re: DG
02/07/2012 3:44 AM
Power = √3 V I CosØ
= 1.73 x 415 x 700 x 0.8 Assuming voltage 415V
= 427 kW
Depending on the load , like if it is single unit, the staring current will be much more. If it is small loads together, like 100+125+ 75+ 50 + 150+100+200, the staring current can limit by scheduling the starting of machines.
Re: DG
02/08/2012 10:23 AM
thnks arif
I have to run welding & drilling m/cs on dg. how much percent of additional power i need
Re: DG
02/09/2012 1:58 AM
What are the loads of machines ?
This case of welding machines and drilling machines need more attention as it is not a constant load.
If it would have been a normal load 500kVA is Ok. The load is 80% .
But your load is not a normal load.
arifkunnath (2); PWSlack (1); ravimumbaikar (1); Tornado (1)
