Previous in Forum: Ac Motor   Next in Forum: Energy Saving for Constant Torque Loads
Earth Strip Size Calculation
02/07/2012 11:41 PM
hi all
how to calculate the earth strip size for 2500 kva t/f
Good Answers: 181
Re: earth strip size calculation
02/08/2012 1:48 AM
Try opening your textbooks!
We will help most people but those that are to idle to help themselves usually get short shrift.
I did look at your previous post before writing this.
02/08/2012 2:19 AM
hello mr tonys
if u dnt like this type of questions means pls keep silence and i dnt need this type of answers ok
Register to Reply Off Topic (Score 9)
02/08/2012 3:36 AM
Simple. Refer to British Standard 7671.
Re: Earth Strip Size Calculation
02/08/2012 3:10 PM
Since you give no indication where you are, and your other questions indicate a lack of knowledge of electrical systems, I'd suggest a short course in electronics.
If British Standard suggested by PW Slack isn't applicable, maybe the NEC (National Electrical Code) will work for you.
You can also search for the NUMEROUS web sites that can do this for you.
I'd suggest searching here: Search GlobalSpec for possible solutions.
I'd also suggest that you use a search engine BEFORE you come here, so that you will have enough knowledge of the subject to ask relevant questions if you need real help.
02/12/2012 1:25 PM
It also depends on local and international standards, some (for example) require 100% redundancy (by adding a second earth conductor/busbar, etc of the same size) for certain transformer applications.
Have you tried an internet search?
Good Answers: 170
02/16/2012 10:11 AM
Please refer to IS 3043.
Register to Reply 6 comments
abinesh (1); electricalexpert65 (1); jack of all trades (1); lyn (1); PWSlack (1); TonyS (1)
