Previous in Forum: Efficiency of Induction Motor   Next in Forum: DI Electric Constant
18 comments
Are We Produce Electricity from Tree ?
02/11/2012 1:19 AM
I read news from General of AMIE : Electricity generate from tree, Its true or false? Any body have information from this point , please share with me in details. Please send any project which was implemented from above technology.
Thanks & regards
Mahavir Verma
Sr Engineer from Noida-UP (India)
All engineering doubt clearance
Re: Are we produce electricity from tree ?
02/11/2012 1:27 AM
Maybe, but not very much.
The best bet for this would be to cut down the tree and burn it in a boiler, which in turn drives a steam turbine. However, this would lead to deforestation problems.
02/11/2012 1:33 AM
wat about solar energy?
02/11/2012 1:40 AM
Okay, one could hang some PV arrays on the tree.
02/13/2012 3:32 AM
What about it?
02/11/2012 1:38 AM
You we i do. Can you?
02/11/2012 1:44 AM
This is not new....
"By stacking one electrode into a big maple leaf, and another in the ground, the tree generated a tiny stream of electricity. The amount of energy generated by this tree is very less a few 100 mili Volts , but this energy is insufficient to even light a bulb, so the scientists built a custom made Voltage boost converter using nanotechnology that stores input voltages of as little as 20 mV (20 thousandths of a volt) and produces 1.1 volts
Application in Future: This energy is enough to run low-power sensors...
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
Re: Are we produce electricity from tree ? Use Potatoes
02/11/2012 7:02 AM
Perhaps you mean by the same principle as this?
Chaos always wins because it's better organised.
Good Answers: 918
02/11/2012 8:04 AM
Yes, but it sucks the life-force from the tree.
Good Answers: 125
02/11/2012 8:22 AM
If the desire is to generate electricity from Flora, stick to potatoes and lemons. At least they are already dead.
Good Answers: 75
Re: Are We Produce Electricity from Tree ?
02/11/2012 10:00 AM
I've been thinking about this....would it be possible to power house lighting (using LEDs obviously) from / by the houseplants?
Should I build my house around several trees to provide power for low voltage items?
Good Answers: 918
02/11/2012 10:22 AM
I think you will need all of Sherwood Forest to do that.
02/11/2012 6:41 PM
Houseplants? If they were the right type of houseplants, then yes...
02/11/2012 11:27 AM
These guys think you can: Voltree
02/11/2012 7:19 PM
What power level is in mind? Micro/milli/kilo/giga watts?
02/12/2012 8:19 PM
I think in Pandora, Na'vi just use it.
Good Answers: 804
02/13/2012 12:40 PM
Do a search on "Piezo electric tree" and you will find a lot of information on ideas in the works to create tree-like structures with piezo electric cells in the "leaves" that will each create small amounts of electricity, but the aggregate total will (in theory) be useful. No discussion of the cost though, this is pretty much an engineer's pipe dream at this point.
02/28/2012 5:13 PM
From trees - No. But you can use Current bushes for dc power. You just need to connect a red currant bush to a black currant bush and juice will flow between them.
Good Answers: 75
02/29/2012 3:35 AM
Groan.....
but GA
Register to Reply 18 comments
Anonymous Hero (2); Anonymous Poster (1); English Rose (3); Graebeard (1); iftikhar129 (1); JRaef (1); lyn (1); PWSlack (1); SolarEagle (2); sunny.sun (1); Tornado (3); WJMFIRE (1)
