Previous in Forum: Siemens Turbine SGT400   Next in Forum: Frequency 50hz System by 60 hz System
26 comments
Good Answers: 44
Cr4p I Find on the Internet
02/17/2012 3:38 PM
From GardenWeb.com's Home Electrical Wiring section:
"I'm trying to understand those wires in my house (I haven't been paying attention in school :-) and I have one question: where does the neutral wire come from? My understanding that the power company only supplies the hot wires, and the neutral is tied to the ground wire at the main service panel, but looking at the diagram below there's a white neutral coming in."
Response from an astute "electrician":
"The neutral wire is the return path for the spent electrons to return to the transformer for re-energizing. The neutral completes the path so that the transformer can keep functioning. There are two types of power distribution: Wye and Delta. Wye, more common and newer, uses 3 phases plus a neutral conductor. The neutral is grounded both at the substation and at every power pole. Delta uses 3 phases and no neutral. In Delta there is only a single voltage, between two phases (phase to phase), while in Wye there are two voltages, between two phases and between a phase and neutral (phase to neutral). For further reading do a Google search on AC power generation and distribution."
Wow...
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
Re: Crap I find on the Internet
02/17/2012 4:50 PM
Wow indeed.
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
02/17/2012 4:53 PM
That sounds like an "e-how" presentation.
e how is the most useless thing on the internet!
Here's an example.
How to change a tire:
Jack the car up where the tire needs replacing.
Use the car jack to jack the car up.
Place the jack underneath a solid, fixed place underneath the car (like part of the frame). Don't try jacking the car up underneath the muffler or axle because it will damage the car.
Read more: How to Change Tires | eHow.com http://www.ehow.com/how_4479420_change-tires.html#ixzz1mg71JY8D
02/17/2012 7:15 PM
I think the big question here, is what the H-E double hockey sticks were you doing on e-how, looking up how to jack up a car.
02/17/2012 7:23 PM
It was a subject I chose at random because most of us understand how to change a tire. Imagine, if you had no experience with a car and this was your only source of information. It's an insult to even semi-intelligent people.
Besides, I don't change tires any more, we have Triple A.
02/18/2012 8:08 AM
Yeah, I've ended up on ehow when looking for something. Haven't found one topic description that isn't worthless.
Good Answers: 804
02/18/2012 10:31 AM
"It's an insult to even semi-intelligent people."
But don't forget, only a small portion of the world population is even "semi-intelligent".
02/18/2012 5:23 PM
I once submitted a piece to ehow and it was shot down as unworthy.
02/19/2012 5:15 PM
Did you use words with more then 4 letters?
02/20/2012 10:19 AM
I don't think so. It was probably too simple.
I had water seepage on one corner of my basement when it rained. It was down low and I didn't feel like digging out the exterior wall. I figured if I dumped the ash from my wood stove around that outside corner, the rain would carry it into the ground and eventually stop the leak..............................it worked.
Good Answers: 804
02/17/2012 5:12 PM
This was the "wow factor" for me...
"..return path for the spent electrons to return to the transformer for re-energizing"
The rest of it is superfluos drivel unrealted to the context of the question, but that first statement was, well, just... wow...
02/17/2012 5:15 PM
I have read a few pretty ridiculous responses here at CR4. I sort of remember reading in this forum somewhere about those spent electrons being recharged.
Good Answers: 213
02/17/2012 11:53 PM
I recently read an editorial about the threats to the Internet. One thing the columnist missed was that the Internet is becoming overwhelmed with superfluous content. Mostly useless, but some down-right dangerous. When was the last time you did a search for which the first two or three pages weren't filled with some marketing promotion by representatives of Chinese vendors??? Try a search with "energy" in your string- most likely, you will have a minimum of five pages of over-unity hits before you find anything real. The loudest voices get the attention- and, generally, those who scream loudest have less evidence to support their position. If you don't already know where to look for the information you are seeking, it is getting harder and harder to find it...
Good Answers: 16
02/18/2012 12:23 PM
Also, most is not dated as to original entry or update actions along with insufficient/no documentation or substantiation. As always "buyer beware".
Good Answers: 102
Re: Cr4p I Find on the Internet
02/18/2012 6:35 AM
You get that.
02/18/2012 6:38 AM
Hi Guys,
Sounds awesome!! I like it )- Some more sharing about wiring houses made be difficult...
Good Answers: 18
02/18/2012 7:36 AM
The electrician's answer isn't so dumb, actually. The 'spent electrons getting reenergized' sounded way out at first, but when you think of it that's exactly what happens.
Energetic electrons at the live transformer terminals flow through loads that drain their potential energy and transform it into heat or work. The electrons, depleted of some of their potential energy (for a given electron, voltage drop times its charge), go back to the transformer, through which they flow and have their potential energy restored.
Thus, electrons DO get reenergized. Work is done on them in the transformers, which raise their potential energy.
Do unto others. Then run.
02/18/2012 8:16 AM
Maybe, but the OP has no business even thinking about messing with the wires in his house, and for all practical purposes, the answer could have been a description of steam turbine electrical generation. I doubt the OP came away knowing what the "white" wire really does.
Good Answers: 44
02/22/2012 3:44 PM
I hope you don't mean me OP and meant GardenWeb OP...
One additional part that anyone failed to mention was the connection points to delta and wye and how one derives voltages from the phases...I found that quite interesting
As to the "travelling" of electrons to and fro...we're talking AC here...the "movement" of electrons isn't creating electricity. Electrons do not lose their charge. If an electron needed re-energizing it wouldn't be an electron anymore. One also cannot change the speed of electron "movement" (~.01 cm/minute) by pumping up the voltage...if we could do that then we could change the speed of light by varying color temperature...oops...wait...what color were those electrons? Are they red-shifted?
02/22/2012 3:56 PM
Yes, the garden web OP.
Hmmm, I've got an electrical question..................I think I'll go find a gardening site to find the answer.
02/18/2012 10:20 AM
According to Dave Barry, most folks don't examine their electrons closely and the power companies have been reselling us the same electrons for years!
Good Answers: 74
02/18/2012 5:52 PM
And then all those who get killed while they pay the bills.
I'm the one that will not go near the whole department. It's a dangerous hobby and should only be carried out under strict supervision, if at all carried out by the handy man. Gosh I hate that twitching sensation.
Coming to think of it any of the major trades have their danger zones. All our collective scars are proof of that and many of them could have had worse outcomes, at least mine.
Picking up a trade by watching Utube could have very serious consequences. Recognizing hints and specialties can be very enjoyable for the knowledgeable, learned observer though. Outlawing stupidity?...............
Darwin's 'Theory' and Murphy (I'll get you one day) will be in charge, whatever our business.
The Twain Has Met
02/20/2012 12:14 PM
*usually 50 or 60 times every second. Just how much is an electron really worth, I wonder?
Good moaning!
02/18/2012 11:36 AM
You ought to publish the name of the electrician, I would not have him any where near to my house. Nor should anyone else either.....
Also anyone who somehow reads any sense in his words is as misinformed as he is.....
The comment was completely and utterly wrong, but that is the state of training of some electrical people around the world....I have met them time and time again, some on CR4.....sadly.
To answer the OP, either a neutral is supplied by the service company, or one is made locally "in house" in one of several possible ways depending where you are and local code.
The main rule is that the neutral to ground link may only be made once.....local codes apply.
Good Answers: 102
02/20/2012 9:28 PM
Then there's the single wire earth return (SWER) systems that you find way out in the bush.
02/21/2012 10:02 PM
Yup... My electric fence :-)
Engage mind before action
Good Answers: 102
02/22/2012 2:40 AM
Very good.
Register to Reply 26 comments
Andy Germany (1); Captain Curious (1); Crabtree (1); cuba_pete (1); cwarner7_11 (1); Doorman (1); DreadZontar (1); ggicollegepunjab (1); Graycav (1); JRaef (2); kramarat (6); ky (1); lyn (2); Rixter (1); robin.muir (1); tonykuphaldt (1); Wal (3)
