Previous in Forum: solar power   Next in Forum: Life Time of V-Belt
11 comments
Hydraulic Trandsducer?
02/28/2012 3:10 PM
I'm looking for a transducer that I can put in my hot tub to mimic a strong water jet. Can anyone direct me toward a company that might make such an item? It would need to send out strong vibrations of at least 1800 cps. I can't give a pressure level, not being an engineer.
goosemydog
Pathfinder Tags: Massage Hydraulic Vibrator
Re: Hydraulic Trandsducer?
02/28/2012 3:13 PM
Possibly a high-powered underwater speaker.
02/28/2012 3:20 PM
Just a word of caution.
Putting a transducer into water that contains human bodies will directly couple the energy from the transducer to the body.
This might cause damage to internal organs and skeletal joints.
You might want to do some research before subjecting your friends to this energy.
Good Answers: 27
02/29/2012 11:16 AM
I agree, kind of dangerous experiment. - The same technique using adjustable sound waves used in lithotripsy, where internal calculi, kidney stones, etc. are broken down into small enough size to enable its normal passing into the urethra for excretion..
vsar
Good Answers: 101
02/28/2012 6:48 PM
Could be dangerous... I would simply use a pump, and pump the water through the nozzle, like all spa's have done for decades... it works well, is simple, and won't hurt people.
02/28/2012 6:54 PM
What a bunch of chickens. If you do it right, you will get full-immersion Magic Fingers. I'm not sure about the 1800Hz; bone-thrumming organ tones might be better.
02/28/2012 11:45 PM
I agree - depends on the power; even a few hundred watts @ the desired frequency are likely to be just a tickle. I would think it would be more of a challenge to increase the power to get the desired effect.
HOWEVER, I reserve the right to be wrong.
Good Answers: 102
02/29/2012 2:15 AM
Speaker came to my mind too.
What does OP want to clean in the bathtub?
Good Answers: 143
02/29/2012 7:51 AM
Lubell Labs made the underwater speakers for at least the 2000 Olympics. They cover the range you want and have pretty good power.
03/02/2012 5:52 AM
In place of electronic/electrical device, actual pump and nozzle will serve better. May be you do not like that.
03/02/2012 12:36 PM
Maybe they want a large sub-ultrasonic cleaning tank. Always thought of that for car engine blocks.
deanpavil
Good Answers: 101
03/06/2012 7:47 PM
Just make sure to avoid the "Brown Note" frequency, or you might end up cleaning the system prematurely.
Register to Reply 11 comments
deanpavil (1); lyn (1); Mikerho (1); Mukesh0861 (1); RVZ717 (2); Tornado (2); TVP45 (1); vsar (1); Wal (1)
