Previous in Forum: Secondary CT Leads   Next in Forum: How to Get the Right Number of Turns in an Undervoltage Coil?
47 comments
Hobbies - Automotive Performance - New Member Engineering Fields - Piping Design Engineering - New Member South Africa - Member - hope to be more
How to Reduce a Fan Motor Speed
03/01/2012 1:48 AM
Hi all,
Need some help. I have a room stand ventilator (220 v 250w), real nice and industrial looking, but hell it does blow. Even on the lowest setting it blows too hard. I thought of putting a dimmer switch to reduce the power even more. Can one do that or will it lead to problems like the motor overheating or something like that. Or do you know of something I can do to reduce the motor speed.
Had looked at reducing the pitch of the fan but it is made of a fibre plastic.
Your advice will be appreciated.
you have to go , to get somewhere
Pathfinder Tags: fan motor speed
Re: how to reduce a fan motor speed
03/01/2012 1:52 AM
Use very heavy fan leaf,...so speed will reduce probably
03/01/2012 1:52 AM
How about just blanking off part of the fan with a cardboard ring, leaving the center open to maintain air flow over the motor?
03/01/2012 2:04 AM
Nice one TORNADO, coming from you, that is a good one. I like the looks of the fan, part of my office and actually would like to keep that look. It was stupid of me getting it in the first place. But now that I got it, it is quite useless since I like only a very soft air movement around me.
03/01/2012 6:23 AM
OK mask it at the back with an annulus of thin polycarbonate.
03/02/2012 12:24 PM
I have experienced problems with restrictions in the intake of blower fans. The motors burned out in an unusually short time. We measured the current through leads of the replacement OEM motor and found the current to be above the rated FLA. When we opened up the intake vents, the current went down to normal.
The manufacturer said that they wouldn't replace, under warranty, the blower fans again if the restriction remained in place.
It gets interesting when you put fuel and oxygen in the same molecule, without allowing them to react, YET!
Good Answers: 804
03/02/2012 2:14 PM
"I have experienced problems with restrictions in the intake of blower fans. The motors burned out in an unusually short time. We measured the current through leads of the replacement OEM motor and found the current to be above the rated FLA. When we opened up the intake vents, the current went down to normal."
Probably was not a centrifugal blower, in which case you pulled a vacuum and overloaded the motor.
03/02/2012 3:49 PM
With most fans that I have seen, restricting the air in UNLOADS the motor and it speeds up. Try it with any vacuum cleaner.
Restricting the exhaust loads the motor up......
Did you get the position of your restriction wrong?
03/01/2012 3:43 AM
As the power of a fan varies with something like the cube of the tip speed, the motor is not likely to suffer too much if the speed is reduced to, say, 1/3rd. I say, hook-up a lighting dimmer to it and try it out.
Good moaning!
03/02/2012 10:19 AM
Is your icon from the Pink Panther movies; or from where (if you don't mind)? I am pretty sure I've seen that (actor) image before.
03/02/2012 1:16 PM
Allo Allo
I thenk yud bitter tek a lick hur
http://en.wikipedia.org/wiki/'Allo_'Allo!
Ha Ha I've caught out the spellchecker.
03/14/2012 10:02 PM
Thank you, Randall, that was interesting and cool!
I have seen that show: WHYY, channel 12, here in Philadelphia.
"Are you trying to give me the business?" (Curly of the Three Stooges)
03/15/2012 5:43 PM
These pictures are from Hugo, academy award winning film released in Nov. 2011. It was shot and released in 3D. So far world wide gross is over $160 million.
Good Answers: 94
03/16/2012 9:26 AM
"I am mauving in a ginger fashion becerrs my poloceman's pints are full of dinamote!"
03/16/2012 10:29 AM
You're in good company:
Immanuel Kant was a real puissant
Who was very rarely stable.
Heidegger, Heidegger was a boozy beggar
Who could think you under the table.
David Hume could out-consume Wilhelm Freidrich Hegel,
And Wittgenstein was a beery swine
Who was just as schloshed as Schlegel.
There's nothing Nietzsche couldn't teach ya Bout the raising of the wrist.
SOCRATES, HIMSELF, WAS PERMANENTLY PISSED...
John Stuart Mill, of his own free will,
On half a pint of shandy was particularly ill.
Plato, they say, could stick it away;
Half a crate of whiskey every day.
Aristotle, Aristotle was a bugger for the bottle,
Hobbes was fond of his dram,
And Rene Descartes was a drunken fart: "I drink, therefore I am"
Yes, Socrates, himself, is particularly missed;
A lovely little thinker but a bugger when he's pissed!
The Philosopher's Song (Monty Python)
03/01/2012 5:47 AM
Don't use a dimmer switch that is made for lights, it will burn up the motor. You need a fan control switch that you can wire inline between the fan and the wall.
03/01/2012 5:54 AM
We use dimmers for lights and motors. We havent seen any motor burnt out by this dimmer.
03/01/2012 6:53 AM
Good for you.
I suppose the OP should probably just roll the dice and try his luck based on your post. Might work. He'll be smelling smoke if he accidentally turns it down too low though.
http://www.fancollectors.org/info/speed.htm
03/01/2012 6:41 AM
As you have read so far there are a lot of options.
You can impede the airflow circulation in front or at the back of the fan.
You can use a dimmer switch only for brushed universal motors. like the power drill or blender ones. Or a transformer. Or with a diode to use half of the sine wave.
If the motor is an induction motor you need frequency converter to lower the frequency. Or you can shut down powerplants so that the grid frequency drops.
Last method I think of is shortening the blades. smaller fan diameter means smaller airflow for the same pitch. be careful to keep the rotor balanced.
The time is ......now
03/02/2012 4:43 AM
To my mind, the first decent post reading down from the top (sorry Guys!).
Therefore GA.
I wonder if anyone has a decent DIY circuit for a small VFD? I would love to have a copy if possible.....I am sure I am not alone....
03/02/2012 8:27 AM
thanks for the good thoughts .
For what power do you need a VFD? I vas thinking to modify a computer power supply, which is a fixed frequency converter. Maybe inserting a potentiometer or something like that I can change the frequency continuously.
I'll post the results if it works. Or if someone has already done it maybe can share.
tchuss
03/02/2012 9:06 AM
A computer power supply is generally a SMPS and it produces DC, not AC.
The frequency used in the electronics (which will be difficult to tap into and could even be inside a chip) is also generally in the KHz range, sometimes VERY high KHz.....
Please explain for us all the logic behind your comments.....
03/02/2012 7:10 PM
well thanks for not letting me to burn a power supply. I think I was wondering aimlessly. I just forgot about this little detail contained in switched power supplies.
In my mind the supply should put ac in the magnetic choke.
03/02/2012 10:17 AM
I agree. GA on your GA.
03/01/2012 7:08 AM
...or direct the fan at a wall and rely on the turbulence generated reducing the force of the wind.
Good moaning!
03/01/2012 7:37 AM
Reverse the rotation.
Good Answers: 125
Re: How to Reduce a Fan Motor Speed
03/01/2012 12:09 PM
Use a rheostat rated for 220 volts and 250 watts (I would size for 300 watts). This will give you 0-max fan speed control and will not damage the fan motor.
03/01/2012 2:09 PM
I'll bet you that buying a different fan that moves less air will be much cheaper than any modification you do to this floor standing fan. I'm all for being frugal with my money but this seems silly and potentially dangerous to me to capriciously reduce the airflow of the whole fan.
If my only choice was to modify this fan or live with the airflow, I'd first live with the airflow or turn it OFF. If my work required using only this fan to make a diffuse, gentle airflow I'd consider changing the blade or cowling design in some fashion to reduce the airflow. I would consider ducting the whole airflow to then take out just some part of the flow from the initial duct.
It will be so much easier to just buy a smaller fan.
Good Answers: 804
03/01/2012 5:03 PM
First off, I'm going to assume since it is a portable plug-in fan, it is a single phase motor, not 3 phase.
You cannot apply a "dimmer" (voltage control) to it until you know, unequivocally, what TYPE of motor is it. Only two types can be controlled that way. They are;
A Universal Motor as previously mentioned, such as you find in a drill motor or blender. It is highly unlikely that you will have a Universal Motor on a big fan like that.
A "Shaded Pole" motor. Many fans are in fact Shaded Pole motors and they can be controlled by reducing the voltage, which doesn't REALLY reduce the speed but it allows the slip to increase. Normally an increase in slip results in an increase in current, but they make Shaded Pole motors to be inherently current limiting so that they don't overload. That then means when you increase slip but do not allow an increase in current, you lose torque and THAT causes the fan to slow down. It is not very stable, but most of the time you can't tell on a fan. If it is a Shaded Pole motor, then you can use a "rheostat" type dimmer to control the speed. But you CANNOT use just any off-the-shelf electronic light dimmer, because many of them dim lights using a switching method that will NOT work on a motor (called "Variable Time base Zero Cross switching). There are electronic voltage controllers that will work, they would have to say "Phase Angle Controller" on them., but they are not the type you typically find in a hardware store. If you find one that does say 'Fan Control" potentiometer, that should work. 250W should be well within the range of most products on the market.
Any other type of AC motor CANNOT be controlled by simply reducing the voltage. it will burn up. If your motor has one or two "bumps" on the side of the motor case, it is a Capacitor type motor, NOT a Shaded Pole type and you cannot control the speed that way.
If it says it is a "Permanent Split Capacitor" type, then you CAN use what is called a "Variable Frequency Drive" that is specially made for a single phase motor. You cannot use a 3 phase VFD, nor can you use a VFD that accepts single phase input and puts out 3 phase (because invariably, lots of people post those part numbers without reading the pertinent data). The problem is, those single phase OUTPUT drives are most likely going to cost you more than you spent on the fan. If it does not SPECIFICALLY say it is a PSC motor, you cannot use that option anyway.
So all that's left is that it is a capacitor type single phase motor, but NOT a PSC motor. In that case, I like the "cover part of the air flow" option.
More than you wanted to know eh?
Register to Reply Good Answer (Score 9)
03/02/2012 9:46 AM
Great answer.
You also recognize that the OP probably couldn't tell the difference between any of these electric motors unless a label from the motor manufacturer was still present on the motor case. Way too many people on this forum don't understand the difference between the various types of AC motors.
What stuns me even more is how many forum contributers still fall for and present anecdotal fallacies in their answers.
Good Answers: 94
03/01/2012 7:16 PM
You could reduce the diameter of the fan blades as suggested earlier or make the blades narrower.
Is the fan one piece or blades fixed to a hub?
03/01/2012 11:03 PM
There have been motor speed controller kits/projects in Silicon Chip magazine. A kit for this is available from Jaycar Electronics, it costs $A100. Cheaper to pick up a fan from the roadside garbage.
Jim
Good Answers: 117
03/02/2012 1:44 AM
Cut the fan blades back with a pair of scissors.
France - Member - New Member
03/02/2012 4:11 AM
Variable Speed Drives do exist for that .... on top of it they may pay for themselves on the electricity savings .
03/02/2012 6:07 AM
If this is a single phase room fan or wall ventilator there are available radio remote control sockets which have on/off and speed or dimmer control. So no wiring involved just plug one into the power point you wish to control and register it with the hand control and the job is done.
I use one for personal cooling and the control is from zero to full speed with no overheating problems so far.
This type is not as common as straight on/off types have a look on google, here is a starter link.
http://www.dlf-data.org.uk/products.php?groupid=2993&sortname
03/02/2012 6:38 AM
A method that may work for you if it is a single phase motor of some sort, that I have used from time to time over the years is to put a switch in the power line with a suitably dimensioned Diode across the switch. (The diode must be of a working mains voltage at least double the mains voltage - more is better, and able to take at least twice the expected current - again more is better!)
In Europe and the UK, I manage to fit it inside the mains plug with a little ingenuity!! In the USA that may not be quite so easy with the small plugs that I have seen.....so a small solid plastic box in the mains lead may be needed. An on/off switch can also be easily be included if required. I would recommend an on/off switch with a power on indication, that can be achieved with a single pole 3 position switch, see here:-
When the switch is in the Half position, the Diode is then in circuit and it "chops off" one half cycle of the mains. This means that the motor (in this case) gets a half voltage mains at half frequency, this reduces the power considerably and makes fans a lot quieter, with much less RPM, effective air movement and power usage.
Most fans then run at about (eyeball check!) half speed.....but no guarantee as I don't know what sort of fan motor you have. Do make sure that it does not overheat when using such a method. I have never had a problem in this area, but you never know.
By the way, the same method turns an old fashioned soldering iron into a fairly hot iron that when given full voltage is quickly at soldering temperature again, but does not burn it's bit up when not being used, but switched on with only full mains.....you quickly get used to flipping the switch when working....
I have used this method to cool the coils of my various (over the years) caravan's fridge coils, so that the fridges work still even when its 50°C outside. Having only full speed at night can be annoying....nor is it needed when the temperature drops to say a cool 35°C!!
For caravan Fridge's, another possible method is to have two absolutely identical mains fans and switch them between parallel and serial mains voltage connection with a 2 pole 3 position mains switch. Middle is then power off.....
K.I.S.S.
03/02/2012 7:14 AM
As mentioned before, can't see why you could not use a dimmer-type speed control.
It's not a small fan, so it probably uses a permanent capacitor (easy to check), not a shaded-pole motor. No need for a VFD, though.
We use a lot of ceiling fans with dimmer down here.
Transformers or rheostats are expensive, cumbersome and... hot.
Half wave operation (diode) will damage some motors.
Shortening the blades is not so easy because of balancing.
Brgds
Snel
03/02/2012 9:03 AM
The only way a half wave (diode) method may damage a fan motor is if the motor overheats, nothing else will be damaged.
Over heating can be easily checked out with say checking every 5 minutes for an hour.
In spite of using this method many times over the last 30 odd years, I have never ever seen a fan motor overheat, quite the reverse, hot motors often run cooler!!!
I expect that somewhere out there is a type of motor that overheats, which is why I never say never, which is also why you need to make sure before using the method for a long time unwatched, but I don't think they would be used for fans though.....
My present caravan I have had for 12 years, I built in such fans in the first year. They run continuously on-site (when mains available) to keep the back of the fridge and the oven cool. Usually on low speed!!! Never had a problem.
Its not as though I am speaking from a position of completely no experience either.
Please would you be so kind as to explain your base of knowledge/experience and detail for us all here which fan motor types will be damaged and how they will be damaged.
I am keen to learn more from an expert.
03/02/2012 10:49 AM
Hi Andy,
you are right, the only damage mechanism is motor overheating by the additional DC at lower rpm. Overheating is less likely with a fan than with other loads.
I have seen at least one fan motor damaged by DC. Ceiling fan motors are "inverted" (fixed shaft, rotating housing) with many pole pairs for slower turning. The windings have not so many turns each and have some empty space from the core, meaning good cooling. A capacitor is used for phase shifting. A friend of mine connected the motor by mistake to a 3-position diode switch which was supposed for light dimming. It worked, but it burned out after some time.
A standing fan will have a different motor. A diode is an option, but even a triac circuit should not go to "zero" as in lamp dimmers, or else your motor may stop and burn out.
"Lowest setting" means the motor probably has a tapped winding, which cannot be easily expanded.
Brgds
Snel
03/02/2012 11:26 AM
Then we are in agreement, as long as he takes the time to make sure that the motor doesn't warm up, he could try using the diode method, cheap and cheerful!! (My family originated in Scotland, is it not obvious?)
Thanks for your post.
03/02/2012 9:26 AM
I don't know why there is all the beating about the bush on this matter, I have given him a perfectly good and simple option. It is just a 250 Watt fan not a very big unit.
The controllers are Triac controlled so the average current will decrease with decreased voltage so there will be no overheating.
Why does eveybody want to complicate the matter?
03/02/2012 9:39 AM
You are right Garth, its a perfectly simple matter.
Some others here like poking their fingers in where they have no experience and less knowledge....
Have a great day.
03/02/2012 9:55 AM
Hi,
You talk of Lowest Setting..It implies that you already have a speed regulator In built in the Fan..like all ceiling/ Wall or Pedestal Fans.
What you need is another Similar type of Regulator Put in series with the first one.
Sure it will work..
Good Answers: 125
03/02/2012 10:22 PM
From time to time, some here go a little hard on those who offer anecdotal answers to incomplete questions. Paying customers usually get the most complete advice...excuse me for being curt.
Good Answers: 123
03/05/2012 10:26 AM
If part of the appeal of this fan is the aesthetics of it, why not just leave it turned off, and put a small low volume fan behind it out of sight.
Bob
03/05/2012 11:22 AM
Thanks' all your contributions just proved to me that I am not the only one ever thought about this.
I had the most entertaining weekend reading and evaluating your comments. I am going to get a smaller fan for the time being but will tackle this problem as soon as I have some free time on my hand. Really would like to try the diode method of Andy Germany , and the dimmer way as well.
What I have done in the meantime is I changed the cutting edge by slipping a spilt open nylon air tube over it. It increased the speed of the fan a bit but reduced the airflow by I would say 25%
Once again thanks for the contributions.
06/22/2017 4:14 PM
renewing discussion.
i have floor fan and i would like slowing it down. :) im newbie on electronic and motors. have soldering skills thats it :)
for simplicity adding photos of fan and switch
looking for simplest solution to slow it down. if need buy something please drop link or img example. my English is not native and sometimes misunderstand explanations. ty.
02/16/2018 5:56 AM
You have your answer in the thread, above your post.
PS: Most likely the fan has an induction motor so you need a VFD (variable frequency drive) to alter the rpm.
Register to Reply 47 comments
Andy Germany (7); Anonymous Poster (2); bob c (1); Crabtree (2); DRFREON (3); edenlt (1); garth (2); herbie (2); JIMRAT (1); JRaef (2); kkgupta (1); kramarat (2); Lapin (3); lyn (1); Nigh (2); nikolay (4); obouill (1); Randall (2); redfred (2); Snel (2); Tornado (1); WJMFIRE (2); Yusef1 (1)
