Previous in Forum: How to Reduce a Fan Motor Speed   Next in Forum: What is Right Voltage Measurement for Personal Computer or Laptop?
8 comments
How to Get the Right Number of Turns in an Undervoltage Coil?
03/01/2012 7:17 AM
Hi,
I was asked to rewind a 110 volts dc undervoltage coil for a 600AT breaker. I found out that there is a two kind of wire (series connected). The first is #41 AWG with approximately 6000 turns and the second is #32 AWG with 1500 turns (I counted them myself). To illustrate further there is three terminals, one is from the end of the #32AWG, and the point where the two wires are connected, then the end of the #41 AWG. Here's my problem, I used # 33 AWG instead of #32 AWG and # 40 instead of #41, then I rewind with #33 AWG with 1000n turns and #40 with 11000 turns. The winding does'nt overheat but it's solenoid does'nt retract and I think the spring is too strong. My question is what is the right turns so that it could work.
P.S.
The connection is this, terminal 1 and 3 is connected with positive 110 volts dc line and line 2 connected with negative (terminal 1 = end of #33 AWG, terminal 2 = middle of #33 and # 40 AWG and terminal 3 = end of # 40 AWG). Terminal 1 has a Normally Closed limit switch.
Please help with my problem.
Thank You.
Re: How to get the right number of turns in an Undervoltage Coil?
03/01/2012 7:28 AM
Why did you use a different size of wire?
Good moaning!
Good Answers: 131
03/01/2012 9:30 AM
What Crabtree said! The manufacturer wound the coil with certain gauges and # of turns of wire, based on a design that took into account the operating parameters of the solenoid. For you to change it to something different without understanding what those parameters are and being able to calculate the proper # turns of your size wire (if possible at all in the space allotted) is useless. Get the right size wire! We can't do the work for you here, since we have even less info about the coil and solenoid than you do.
Good Answers: 58
03/01/2012 10:44 AM
Crabtree...Arrest that man
Good Answers: 181
03/01/2012 11:16 AM
Because, I assume the OEM used two sizes of wire. Read the OP!
Without a connection diagram the rest is guesswork.
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
03/01/2012 11:09 PM
Tony,
I believe he is asking why did the OP use two different sizes to the two original different sizes.
41/32 vs 40/33
Regards,
Sapper
It's all about the Boom! - MythBusters
Re: How to Get the Right Number of Turns in an Undervoltage Coil?
03/01/2012 9:41 AM
India - Member - New Member
Good Answers: 164
03/01/2012 10:41 PM
Modern UV coils are microprocessor-controlled for precision in operation. They are therefore inherently DC operated, even though the sensed system voltage is AC. The two windings are (1) a low resistance pickup winding which is cut out of the circuit after pick up, and (2) the other one is a high-resistance seal-in winding, which is continuously ON.
i wonder whether your coil is one of these....
Ah, sorry, you already said this is a late-break NC controlled one. Your best bet is to throw it away and get a new one from the manufacturer. Even in India, this rewinding of coils is no longer done.
Good Answers: 27
03/02/2012 11:53 AM
For the solenoid to work, its coil needs to draw enough current to generate just enough magnetic flux for it to hold and latch. By replacing its winding to the next bigger size of #40, yet almost doubling the original number of turns, it is going to draw /consume much lesser amount of current and therefore will not generate enough magnetic flux needed by the solenoid to latch and hold...
I think by maintaining the original # of turns and just replacing the wire size AWG #41 to #40 which is one size bigger, should enable your coil to run much cooler as the current drawn will almost be the same.
vsar
Register to Reply 8 comments
Crabtree (1); KJK/USA (1); kvsridhar (1); lyn (1); PeterT (1); Sapper (1); TonyS (1); vsar (1)
