Previous in Forum: Converting CAD Drawing Files Into Graphics-Based Files   Next in Forum: Window 7 & XP Both Installation
SQL Writer Problem
03/04/2012 10:23 PM
I was installing one software from web on my home PC. While istallation, PC suddenly got restarted and following message started to display.
" SQL Dumper library failed initialzation. Your installation is either corrupt or has been tampered with. Please uninstall then re-run setup to correct this problem"
After few seconds PC is getting restarted without complete start up. While restaring same message displays agian and getting restared after few seconds. This repeatation happens number of times but PC doesn't get start.
Can anybody help on this issue?
Re: SQL Writer Problem
03/04/2012 11:13 PM
Try turning the computer off and unplugging it from mains for at least 15 min, then restart. If that doesn't work, we need more info:
  1. Operating System name and version?
  2. Laptop or desktop?
  3. Make & Model?
  4. What program were you installing (also need to know the version!)?
Try the first thing I said. If that doesn't work, come back here with the info requested if you really want help.
03/05/2012 12:41 PM
While mainly being used for safer browsing, I find running installations of freeware "Sandboxed" using Sandboxie is a good way to find out issues that may or may not be some attempt to dink with your computer. It's a way to see what all the software is "trying" to do without repercussions.
Good Answers: 102
03/05/2012 11:48 PM
Seems that some internet hygiene practices weren't adhered to, or you found out why some things are free...
OP, the prognosis is not good and will be difficult to fix if you don't have a recovery file stashed somewhere.
You want to consider getting a separate PC for adventurism once your pC is revived.
You really need a local friend to help and possibly pay them or trade skills.
Register to Reply 3 comments
Anonymous Poster (1); Mikerho (1); Wal (1)
