Previous in Forum: Conversion   Next in Forum: Calculation of Power for Actuating the Lead Screw
9 comments
What is the Cause Of High Vibration on HR Fan?
03/19/2012 8:46 AM
I am working in a Iron ore pellet plant. Hr fan is one of the major part of pellet plant. details below.
The length of Tg is about 32mts.it consists of 4-zone.
Zone-1 - 9mts length-temp about 200'c
Zone-2 - 6mts length-temp about 350'c
Zone-3 - 6mts length-temp about 650'c
Zone-4 - 15mts length-temp about 1100'c
And in all the zone Pressure is maintain negative.Hr fan is used to recycle the excess temp of zone-4 to zone-1 and to maintain negative press in Tg.
Hr fan -630 kw,1460rpm,normal temp at drvie end is 58 and at non drive end is 50.but the time of vibration the temp reach above 90'c at both end.
If you born poor its not your mistake but if you die poor its your mistake
Re: What is the Cause Of High Vibration on HR Fan?
03/19/2012 9:22 AM
It's probably the same cause as the vibration on this one:
http://cr4.globalspec.com/thread/76610
Good moaning!
03/19/2012 10:58 AM
Dirt on the blades.
Damaged bearings.
03/19/2012 11:36 AM
Dead bat in the fan blades.
Innuendo is not Italian for a suppository.
03/19/2012 12:27 PM
What's an HR fan? Tg? Sounds like a bad bearing, or blades out of balance.( )? Shaft could be bent....
Location: Base in Madrid, Spain. Updated location every several months.
03/20/2012 12:42 AM
I do have blowers of the same size and, when vibration comes, I check as follows:
1. Cleaning of the impeller. Bumps, impacts, foreign materials attached, etc...
2. Bearing blocks at drive and non drive end (axial gap in floating bearing, non drive end) Heat diffusors between blower shell and bearing blocks?.
3. Coupling status. (alignment, gaps, parts, rubber blocks if apply...etc.) Specially important the axial gap if the motor has a magnetic (floating) center.
4. Uncouple the fan from the motor, and check vibration in the motor alone.
( some shim missed, tightenign of the bolts...etc.)
5. Expansion joints in the ducts. A bad installation can lead to forces and deformation in the blower shell, and this deformation to unexpected wear or contact points.
5. If nothing is found, You can consider a new dynamic balancing of the impeller.
And, prior to all this...
Preferably in the MCCR as well.
Salu2
Everyday learning.
Good Answers: 19
03/20/2012 3:02 AM
The balance is out due temperature and longtime operation. Get all dynamic balanced.
03/20/2012 8:01 AM
I am not familiar with Iron ore pellet plant and its motor/fan installations.
Any abnormal vibrations in motor are due to bearing problems, shaft alignment problems , foundation fixing problems . If it is a fan of-course blades also plays a role.
Vibrations can cause energy loss. Heat and noise are the results of vibrations.
03/20/2012 3:37 PM
Hr fan, is that a calciner, what's a Tg
03/21/2012 6:04 AM
there were lots of reason for the heavy vibration
1) May be Unbalance mass in rotating equipments
2) struture weak
3) bearing problem
exact cause of vibration you can find out by FFT analysis
Register to Reply 9 comments
abelmh (1); Anonymous Poster (1); arifkunnath (1); Crabtree (1); ducon (1); Horrible Old Bat (1); lyn (1); phoenix911 (1); SolarEagle (1)
