Previous in Forum: Cryogenic and Lethal Vessels   Next in Forum: Calculate Electric Motor Kw Required For a Conveyor
19 comments
What Is The Root Cause Of High Vibration On ID Fan??
03/15/2012 11:27 AM
what is the root cause of high vibration on ID fan‎?
If you born poor its not your mistake but if you die poor its your mistake
Good Answers: 58
Re: what is the root cause of high vibration on ID fan??
03/15/2012 12:11 PM
Lack of concentricity amongst the rotating parts.
What is you opinion?
03/15/2012 12:33 PM
Fan balancing
Bearing clearance
Engineering Fields - Control Engineering - Newby Member Long Time User Engineering Fields - Instrumentation Engineering - New Member
03/15/2012 12:47 PM
Please explain what an ID fan is.
Good Answers: 58
03/15/2012 1:10 PM
Induced Draft.
Used in coal fired power plants and mills among other applications.
03/15/2012 1:13 PM
Induced draft fan draws flue gases 4m d Electrostatic precipitator and discharge d gases 2 atmosphere through d chiminy.
03/15/2012 1:21 PM
It uses is different in different industry but every where concept is same it uses for removing flue gas.
03/15/2012 12:47 PM
Loose mountings too!
Good Answers: 266
03/15/2012 12:53 PM
variation in pitch between the blades
Re: What Is The Root Cause Of High Vibration On ID Fan??
03/15/2012 12:57 PM
Dirt on the blades.
Good Answers: 181
03/15/2012 2:25 PM
The usual culprit in my experience.
03/15/2012 1:10 PM
Dead bat jammed in the blades.
Innuendo is not Italian for a suppository.
03/16/2012 7:25 AM
Why not a dead cat??
03/15/2012 1:48 PM
Impact damage (at site, transport damage), manufacturing defect, lack of lubricating oil/polluted oil, worn vibration mounts, loose fittings/bolts, resonance, incorrect fan and/or blade selection, incorrect installation, loss of one of the phases (for a three phase fan), etc.
03/15/2012 10:04 PM
What are the specs of your ID fan? Without technical details it is like throwing stone in the dark. It may hit the target but why do'nt you switch on the light?
03/16/2012 12:49 PM
ID FAN-900Kw
Rpm-990
03/16/2012 9:49 PM
Mr. Rajesh,
ID fan specs of 900Kw and 990 rpm are not sufficient. So many queries have been raised by responders at least reply those queries.
What is type of fan?(service , design, duty, MOC etc)
Is it a new fan or old, vibrations is an old problem or has started recently?
Had some maint. job taken up recently?
What is the last balancing report of rotor?
If fan is old, when last cleaning was done?, When bearings were inspected?
Is there any change in bearing temperature recorded?
What is the type of coupling between motor/prim mover & fan?
What is the condition of alignment at coupling?
03/16/2012 10:13 PM
It is new fan and running 4m last 1 year.
The problem is started 4m last 3 month.
Their is no modification at their in recent time.
The bearing clearance and fan blade cleanig in last month.
The vibration are constantly high but d temp increase suddenly most of d time.now days d temp rises to 80'c to 100'c.Before 3 month the temp is below 40'c.now d normaly temp is normally 50'c -60'c.
Pin bush coupling is used between motor/prim mover & fan.
Alignment at coupling is also checked in last month and found ok.
what type of grease u r recomend at the time of 100'c.
03/19/2012 9:17 AM
It it's only 4m old, then get the manufacturer in to advice; it must be under warranty, surely?
Good moaning!
03/16/2012 1:31 AM
Give more details. Is it new or it was working for sometime well. If it is new check dynamic balancing by manufacturer once you make sure that it was installed properly.
pnaban
Register to Reply 19 comments
BDThompson (1); Crabtree (1); Horrible Old Bat (1); jack of all trades (1); KJK/USA (2); lyn (1); Mr. Truman Brain (2); Mukesh0861 (2); ozzb (1); pnaban (1); rajesh1986 (5); TonyS (1)
