Previous in Forum: 23 MVA Power transformer IR value   Next in Forum: Earthing
High Bay Light 400 W High Sodium Vapour Lamp
03/23/2012 5:26 AM
Dear friends,
Can anybodytell me at what distance a high bay light 400 W high sodium vapour lamp
must be hanged? what will be heat desipated to ground level in a workshop.
if their is any graphic properties kindly send me , thanks .Suresh
Pathfinder Tags: lighting project
Re: electrical engineering
03/23/2012 5:48 AM
The manufacturer of the lamp would be a good starting point.
03/23/2012 6:14 AM
Manufacture can provide you Heat dispersion factor
You can Simulate the lighting effect in DIALUX software.
reply me if i am wrong.
Good Answers: 58
Re: High Bay Light 400 W High Sodium Vapour Lamp
03/23/2012 10:21 AM
This seems to be informative.
You can also Google the phrase "High Bay 400 Watt High Pressure Sodium Fixture Mounting Elevation" as well as variations there of.
Good Answers: 804
03/23/2012 12:53 PM
So I guess you don't want to burn the tips off of those pot plants, eh?
Register to Reply 4 comments
JRaef (1); KJK/USA (1); PWSlack (1); sriram1988 (1)
