Previous in Forum: High Bay Light 400 W High Sodium Vapour Lamp   Next in Forum: Motora
Earthing
03/23/2012 5:32 AM
How to measure earthing resistance by analog megger?
Re: Earthing
03/23/2012 5:44 AM
Follow the instructions supplied with the equipment.
Re: Earthing
03/23/2012 10:46 PM
Dear all,
If your analog megger is "insulation" resistance tester, you can not measure earthing resistance with your megger. Use an earthing resistace meter.
Regards
Akihito Shigeno @ JGC-Indonesia
Re: Earthing
03/24/2012 3:56 AM
First of all ..........do you know what are the range of Earthing Resistance & insulation resistance of any electrical equipment?
Location: off the beaten track, not quite whoop whoop nor humptydoo
Re: Earthing
03/27/2012 10:18 PM
Hmm, do you mean insulation resistance, or earth continuity?
If earth continuity, probes placed at either end, meter set to Ohms (probably 3 Ohms), press the button, read and record results.
If insulation resistance set meter to double operating voltage, hold both probes and press the test button. If that bites then you know the meter is working. Now put one probe on earth and the other on active, press test button. Read and record results.
Everything works out in the end, just not neccessarily how you want
Register to Reply 4 comments
abele (1); Akihito Shigeno (1); Chook (1); PWSlack (1)
