Previous in Forum: Earthing   Next in Forum: Nuclear Heat
9 comments
Motora
03/23/2012 12:23 PM
How do you connect a three phase motor to a single phase supply?
Engineering Fields - Control Engineering - Newby Member Long Time User Engineering Fields - Instrumentation Engineering - New Member
Re: Motora
03/23/2012 12:32 PM
You don't.
A three-phase motor can only be connected to a three-phase supply.
Re: Motora
03/23/2012 1:01 PM
Not necessarily true - that depends on the HP and voltage - there are many VFD's made that convert 120VAC single phase to 240V three phase - but this only applies to up to 3 HP or so. I haven't found a 5 HP unit yet. I believe there are also 240VAC single phase to 480V three phase, but I haven't used one yet, so I don't know the HP limit on these.
Google "Lenze (AC Tech) SMV(ector)" series. Allen Bradley PowerFlex 4 line also has a 120V unit for 240V three phase.
Re: Motora
03/23/2012 1:06 PM
I didn't know that, I'll look in to that. I had did some work where the grid was only single phase. This would be very useful. Thanks
Re: Motora
03/23/2012 1:15 PM
We use them on the tanks we build with bottom mount mixers. I am having the staff wire one of these almost weekly. I also designed a general purpose VFD center with 5 of these in various HP capabilities for tanks with mixers where the customer will provide a VFD at the plant, but still wants to see the mixer run here at our site.
Re: Motora
03/23/2012 1:48 PM
You learn something new every day.
Thanks.
Re: Motora
03/23/2012 2:01 PM
sure do,
Re: Motora
03/23/2012 12:43 PM
you can hook a single phase motor to 3 phase supply, but you can not hook a 3 phase motor to single phase supply, unless you do this.
use a phase converter.
http://www.phase-a-matic.com/
Good Answers: 181
Re: Motora
03/23/2012 6:52 PM
You can create an artificial 3 phase system. 60 year old technology but it works!
Re: Motora
03/24/2012 10:18 AM
Very good, but I'll bet the AC Tech VFD at less than $200 USD is a cheaper way of doing this.
This is like my college EE project in the mid 1960's where I made a color organ (light box) for 3 sound ranges from the same sort of technology plus a low filter, a range filter and a high filter, because the SCR's were very new then and rather expensive. Yes the old ways still work, but the modern ways are now lower cost.
Register to Reply 9 comments
BDThompson (2); phoenix911 (3); Phys (3); TonyS (1)
