Previous in Forum: Selection of a Distribution Transformer   Next in Forum: Size of Conductor
How to Determine HV Cable Minimum Bending Radius
03/30/2012 6:39 AM
I have a 3x95mm2 HV cable and i want to know the minimum bending radius. when i checked the internet i found this:
Factor x cable overall diameter= minimum internal bending radius
What is the factor?
Can anypne with profound knowledge in the subject matter educate me? is there a chart where i can find minimum bending radius required for HV cables? what factors do i consider?
Thank you very much
Re: How to Determine HV Cable Minimum Bending Radius
03/30/2012 7:12 AM
If only you could Google.
How to Effectively Use a Search Engine
03/30/2012 7:36 AM
Find the telephone number and contact the supplier of the cable! Sheesh!
03/30/2012 9:17 AM
Look in to the cable data sheet and you will find the factors for the cable bending radius.
Good Answers: 170
03/30/2012 10:19 AM
Bending Radius (vide Table 5 of IS 1255:1983)
Voltage Rating
PVC & XLPE Cables
Single Core
Multi-core
Upto 1.1 kV
15 D
12 D
Above 1.1 kV & upto 11 kV
15 D
15 D
Above 11 kV
20 D
15 D
Where 'D' is the overall outer diameter of the cable
03/30/2012 10:29 AM
Thank you very much electricalexpert65 and sincere appreciation to everyone who also contributed.
03/31/2012 12:22 PM
For roundwire or tape armoured ,copper or aluminium cables will the radius of bending be same as non-armoured cable
pnaban
04/03/2012 5:37 AM
17 X over all diameter = minimum bending radius
Register to Reply 7 comments
benotype (1); electricalexpert65 (1); lyn (1); pnaban (1); PWSlack (1); Simon Wan (1); sridharganasen (1)
