Previous in Forum: How to Determine HV Cable Minimum Bending Radius   Next in Forum: Power Factor Improvement
9 comments
Size of Conductor
03/30/2012 6:46 AM
how ll u find a size of conductor...? for a 300A load..?
Re: Size of Conductor
03/30/2012 7:30 AM
03/30/2012 7:37 AM
Simple. Apply British Standard 7671.
05/04/2023 7:38 AM
...which is routine for a qualified Electrician.
03/30/2012 9:15 AM
There is a data sheet from the cable suppliers on the current carrying capacity of the cables. Check it out from there and it will tell you the cable size for 300Amps.
03/31/2012 1:33 AM
thanks.. can u have that data sheet.. can u please send to my mail id is..
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
04/02/2012 4:31 AM
What about using the telephone to talk to cable manufacturers directly?
05/04/2023 7:36 AM
...because one can wait a lot quicker.
03/30/2012 10:38 AM
it is long long procedure to tell you. Please forget it.
Good Answers: 181
03/30/2012 11:36 PM
Look to your last thread.
Register to Reply 9 comments
lyn (1); nobodysomebody47 (1); PWSlack (4); Simon Wan (1); TonyS (1); V S Reddy (1)
