Previous in Forum: High Voltage Metering CT   Next in Forum: What is Light ON & Dark ON in Sensors?
Slope Of A Resistor Char
04/04/2012 5:43 AM
how the slope of the vi characteristics of a resistor is 1/R??
Re: slope of a resistor char
04/04/2012 5:50 AM
Has it got anything to do with Ohm's Law?
04/04/2012 6:47 AM
no,but based on the characteristics we can say V=IR
04/04/2012 7:03 AM
Good Answers: 73
Re: Slope Of A Resistor Char
04/04/2012 11:21 AM
Switch axis on the graph. Voltage(vertical axis) vs Current(horizontal axis) is the traditional form of plotting resistance. But, if you plot Current vs Voltage you get conductance, or the inverse of resistance.
This had better not be a homework question or you just cheated and deprived yourself of the learning process.
04/04/2012 11:40 AM
I know how they plot the resistance with i along x and v along y my question is why the slope of the resistance is 1/R.
Good Answers: 73
04/04/2012 12:14 PM
If R=V/i then 1/R = i/V.
The slope of a resistance (or conductance) is a straight line in the linear world. If the slope changes then the resistance changes. The slope should = the resistance using any two points such that:
R = (V2-V1)/(i2-i1)
The only way you can get 1/R is to invert the numerator and denominator.
04/09/2012 12:56 AM
got it guys
equ of straight line y=mx + c
here slope m=(y2-y1)/(x2-x1)
here in v-I char
m=(I-0)/(V-0)=I/V
by ohms law V=IR
therefore from that the slope is 1/R.
thanks for the replies....
malar (3); NotUrOrdinaryJoe (2); PWSlack (1); SolarEagle (1)
