Previous in Forum: Gear Box Ratio, Speed, and Torque   Next in Forum: Jacketed Vessel Hydrotest Pressure Query
8 comments
Booster Pump Use
04/15/2012 6:49 AM
what is booster pump?
what is purpose of booster pump installation?
why booster pump required?
Re: booster pump use
04/15/2012 7:38 AM
Used to boost pressure...Pressure too low...
04/15/2012 10:15 AM
You don't specify if your process is high or low pressure in nature. It does make a difference if you're trying to induce pressurization or vacuumization.
If I remember correctly (always a question) a booster pump would be the first of a two-stage operation in which two pumps are in series. The 'booster' pump is used to either boost or reduce pressure before the second pump kicks in and completes the process of reaching the desired pressure range.
04/15/2012 10:49 AM
04/15/2012 8:15 PM
Well, probably not. But guys like me need questions like that. They make us look like we know at least a little bit about something.
04/15/2012 9:04 PM
I know a little bit about something, too.
I just can't always remember what it is.
04/16/2012 3:38 AM
Thank goodness for Wikipedia, then.
Good Answers: 19
Re: Booster Pump Use
04/16/2012 1:06 AM
Your application is "Pressurized water distribution" call it short-term boosting system.
Processing machines have dictated required pressure as 3.0 ~ 3.5 bar (43.5 psi ` 50.75 psi). Every 27" water column = 1 psi or every 2'-3" = 1 psi. So 43.5x 2.3 = 100 ft head ~ 50.8 x 2.3 =116.7 ft head. Now this means that the bottom of your overhead tank needs to be minimum this head which is not possible so from your overhead tank you cannot get the required psi/head. The supply line then needs a pump (boosting) to develop a pressure 3~3.5 bar to supply the machine (boosting). You then need a separate pump on each machine engineered both for flow m3/hr and pressure. You can have a a centralized system too with a Pressure Vessel and sets of pumps to take feed from underground tank and give pressurized 3.5+ bar on the entire waterline distribution system. this then eliminates your overhead tank usage. All my designed system have this Boosting/Pressurized water distribution system centralized network with NO overhead Tank ever need/constructed. For wash Rooms/utility the branch line supplying as a PRV to reduce pressure to desired level, rest each machine are getting their dictated flow (as per designed size of pipe diameter) and pressure 3.0~3.5 bar.
04/16/2012 1:40 AM
If the pressure of water not enough in upper floor of a house they use an in-line booster pump to increase the pressure.
pnaban
ducon (1); lyn (2); pnaban (1); PWSlack (1); SolarEagle (1); spooklight (2)
