Previous in Forum: Booster Pump Use   Next in Forum: How to Facilitate Conversion Mechanical Pedaling to Electrical Energy?
Jacketed Vessel Hydrotest Pressure Query
04/15/2012 10:18 AM
Dear all,
I have query regarding jacketed vessel hydro test.
Equipment type - Heat exchanger - Tema type BKM - 550-1050X9753 mm
Jacked ID = Channel ID +100 mm
Front & rear channel are steam jacketed to maintain liquid sulphur temperature
Design Conditions -
Code - ASME sec.VIII Div-1 2010 edition + API 660 8th Edition + TEMA class-R 9th edition
Vessel side
Design Pressure (Int. /Ext.) bars G 14.2 / FV
Design Temperature (Int./Ext.)Deg. C 178 / 190
Provided thickness-mm 13
Material SA-516-60
Corrosion allowance 3.2
Jacket side
Design Pressure (Int. /Ext.) bars G 5.6 bars G / FV
Provided thickness-mm 10
Material SA-516-60
I have design inner vessel vessel with internal pressure as 15.25 bars & external pressure as 6.65 bar pressure.
Client specifications calls for shop hydro test shall be as per UG-99(C) & shall not be limited by the nozzle reinforcement.
Query - 1
During hydro test of jacket side which MAP shall be taken.
Shall we consider inner vessel walls as a part of jacket & accordingly find governing MAP for the jacket? (This will be MAP for jacket elements & MAEP for Inner vessel's elements)
If I only consider MAP of jacket shell & head hydro test pressure = 1.3*29.132=37.816 bar
This will be higher than MAEP (maximum allowable external pressure) of inner vessel's elements.
At this pressure inner vessel is failing we need to increase thickness of inner vessel.
Supplier is considering MAEP of inner vessel's head as governing MAWP = 7.2 bar & designed nozzles for this MAWP.MAP is limited by nozzle reinforcement = 8.15 bar
Accordingly hydro test pressure = 1.3*8.15=10.53 bar
Is this acceptable? Supplier is doing hydro test of jacket as per UG-99(b) is this correct?
Query - 2
If I need to hydro test as per UG-99(C) I need to find MAEP of inner vessel in new & cold condition.
Hydro test pressure = 1.3*MAEP (new & cold condition) than inner vessel will not be able to withstand this pressure. Any way we need to increase thickness.
Because likewise in case of internal hydro test pressure we can take advantage of 90% yield but
In this case due to external hydro 90% yield will not work out.
Than what to do shall we limit hydro test pressure?
Please advice.
Share your views.
Re: Jacketed Vessel Hydrotest Pressure Query
04/16/2012 3:37 AM
Discuss the issue with the Engineer/Surveyor for the company that will be supplying burst indemnity insurance. Pick up the phone and do it now.
Good Answers: 181
04/16/2012 9:49 PM
For you to ask the question of a bunch of strangers wouldn't inspire my confidence in you to do design work.
As PWS said speak to the underwriters of the project for your own sake and that of others.
04/22/2012 2:48 AM
I think this forum is made for such discussion & clarification of queries.
It is good to understand other views also.May they have faced similar problem in past or may face.
Register to Reply 3 comments
Mitul (1); PWSlack (1); TonyS (1)
