Previous in Forum: Gas Powered Refrigerator   Next in Forum: Using Air for Heat Insulation
Compressed Air
05/15/2012 6:52 AM
how calculate compressed air volume
Re: compressed air
05/15/2012 6:54 AM
What is the starting point?
Re: compressed air
05/15/2012 7:16 AM
Don't be silly, it's obviously just the same as volume of whatever the container holding it.
Re: compressed air
05/15/2012 7:30 AM
Good point.
<unsubscribes>
Re: Compressed Air
05/15/2012 7:24 AM
As Del said.
But if some type of change is occurring, use the Ideal Gas Law:
http://en.wikipedia.org/wiki/Ideal_gas_law
Re: Compressed Air
05/16/2012 9:41 PM
compressor cylinder displacement x rpm will give you the volume@ zero pressure.
Re: Compressed Air
05/16/2012 10:18 PM
compressed volume is best described in units atmospheric pressure @sea level. 14.7 pounds per square inch ? compressing two atmospheric volumes of air will double the air pressure. that relates to displacement x rpm. if you need to know the volume/ pressure while using the compressor, you'll need to know the output volume needed. intake volume minus output volume should give you the compressor size you need.
Good Answers: 117
Re: Compressed Air
05/18/2012 10:05 AM
Better answer than I would have given to an anonomous poster. Good for you. I would have just sent him to google....
durtieduck (2); PWSlack (2); Usbport (1); user-deleted-1105 (1); Yusef1 (1)
