Previous in Forum: How to Select the Right Temperature Class?   Next in Forum: Unbalancing of Power Transformer
0.55 KW Single Phase Exhaust Fan Motor Cable
06/01/2012 12:04 AM
Dear All,
Kindly tell me that if I can use 1.5 mm cable for starting of single Phase Exhaust fan Motor through DOL.
Best Regards,
Re: 0.55 KW Single Phase Exhaust Fan motor cable
06/01/2012 12:33 AM
What voltage? What is the FLC? What does your local Code say? How long a cable?
06/01/2012 1:15 AM
Dear Tornado,
The voltage is single phase 230 Vac. The FLC as I have mentioned through KW is 2.3 A. The maximum length of the cable is 10 metres. I could not find the local codes but I think that international standards are ok and applicable anywhere.
Best Regards,
06/01/2012 3:44 AM
<...international standards are ok and applicable anywhere...>
There is no such thing as an international code, and therefore it is inapplicable. The North American electrical codes do not apply in Europe, and vice-versa, for example.
In the absence of a local electrical code one might apply the principles embraced by British Standard 7671.
06/01/2012 1:34 AM
Yes, 1.5 mm2 wiring should work for this motor.
Good Answers: 181
Re: 0.55 KW Single Phase Exhaust Fan Motor Cable
06/01/2012 8:06 AM
The simple answer is yes.
You will have .29% volt drop.
06/06/2012 2:16 AM
1.5 sq.mm is okay
but 2.5 Sq.mm copper 50/.25 ( as per IS 694 std)
current carrying capacity up to 21A
Voltage Drop/A/m - 29millivolt
Register to Reply 6 comments
AA039 (1); paulsanal (1); PWSlack (1); TonyS (1); Tornado (2)
