Previous in Forum: Exploded GRP Water Tanks   Next in Forum: Heat Exchanger
Steam Turbine Inlet Connection
06/26/2012 3:11 AM
Steam turbine inlet flange Dia is 6inch,the Steam inlet pipe dia is 4inch Please advice which type of reducer will be correct.
Re: Steam turbine inlet connection
06/26/2012 3:16 AM
Unless I'm very much mistaken, a 4" to 6" one is a good bet.
06/26/2012 3:32 AM
If the turbine has been designed for a 6in inlet connection, presumably on the basis of the expected steam flowrate through its supply pipe, why has the supply piping been run in 4in pipe, which has less than 50% of the cross-section-area of a 6in pipe? In other words, why "strangle" the turbine in this way?
Good Answers: 19
06/26/2012 5:55 AM
I agree with you. This way he will unnecessarily crease pressure drop on the steam turbine blades as well as steam flow will be restricted leading to lower power generation.
I feel he is getting smart by saving money on the cost of the pipes & equipments.
06/26/2012 6:19 AM
It doesn't sound too smart from here.
06/26/2012 1:16 PM
The full size inlet may be required for some steam conditions, but not for all.
Good Answers: 19
06/26/2012 5:50 AM
If Horizontal then Eccentric and if Vertical then any Conentric/Eccentric does not matter.
Good Answers: 67
Re: Steam Turbine Inlet Connection
06/27/2012 4:15 AM
It is strange!!!
Normally pipe size should be either equal or greater than the inlet nozzle size of the equipment
Register to Reply 7 comments
Anonymous Poster (1); ducon (2); pritam (1); PWSlack (2); Tornado (1)
