Previous in Forum: Spray on Batteries   Next in Forum: Water Disinfectors
50 comments
Hobbies - RC Aircraft - New Member Old member.  Heidi;  need to develop paper glider technique.  Use to
Stainless Steel Better Than Wood Or Plastic?
07/07/2012 4:43 PM
Would Stainless Steel be better than wood or plastic or rubber for sand castle push rods. Who could do the metalurgy study of the steel in regard to strength, safeness, effectiveness. What tests would be useful to compare the practical potential of steel, wood, plastic or rubber. I know this covers a lot of ground.
Re: Stainless Steel Better Than Wood Or Plastic?
07/07/2012 5:55 PM
This is my idea of a sand castle. I do not think that this is what you mean, particularly because this has nothing to do with a push rod. Please clarify.
07/08/2012 12:48 AM
I am trying to get a better picture but I hope this helps.
07/08/2012 11:10 AM
No, this doesn't help. What are you pushing with the push rods?
07/08/2012 11:20 AM
I think he's pushing sand out of a box, but you'd better ask tcmtech's six year old to be sure.
07/08/2012 11:43 AM
Pushing sand out of a box does not make sense to me. In all the years I made sand castles, if the sand does not release easily out of a molding box then the box is the wrong material. A push rod will just make a hole in the sand.
07/08/2012 12:01 PM
The push rod is attached to a "push plate" which is the same dimension as the bottom of the box. It pushes all the sand out at once, I think.
07/08/2012 12:42 PM
Yeah, that's one possibility. It seems odd to me that a push rod or plate would be needed to remove sand from a mold at all, let alone that wood or plastic push rods could break in pushing sand out of a mold in any reasonable fashion. The images provided don't help me understand the desired activity nor the problem with using steel wood or plastic in doing that activity.
07/08/2012 12:50 PM
Me, too.
I'd weld a steel rod onto a steel plate and be done with it.
Or, enlist the help of a certain 6 year old.
07/08/2012 1:04 PM
Pretty sure if given the chance she would do the welding herself too!
07/08/2012 1:12 PM
As long as she uses the proper eye protection.
07/08/2012 2:14 PM
Haven't found a kid yet that didn't think my auto darkening welding helmet wasn't the coolest thing ever!
07/08/2012 2:21 PM
One of my boys wanted to view the solar eclipse through mine. That won't work. Not enought light.
We had to go to the "manual" mask.
07/08/2012 1:48 PM
No big deal. Plase read comment to Tornado, #9 reply to #7. Now comes the rest of the day: Emptying (sp?) garbage, pulling weeds, watching our neighbor putting a new house over his old one. (just him and usually a helper), etc., etc. I will be in deep trouble if I spend too much time on this.
Good Answers: 102
07/09/2012 10:28 AM
Instead of building sandcastles why aren't you helping your neighbour build his castle? No point just watching him.
07/09/2012 10:36 AM
That would be a good idea. However there is too much to do around our place.
Good Answers: 102
07/09/2012 11:05 AM
Too much to do? Like building yet another sandcastle?
07/12/2012 1:59 AM
Iget very frustrated ZInoifrn td Znrnlop*ent with thiRiley Lohr I get very frustrated with the operation ofmy my computer. I do get technical help once in awhile. Enclosed is part of the original letter from Riley Lohr which he wrote back in 1977. i visited a Patent Attorney doown (darn) and told him my idea. He suggested dthat I should take hthe mold to the beach and take pictures of my using it. I have soome good pictures of our visit at Santa Cruz showing its use. Luckily I found the pictures just recently and with the help of our computer guro pur put them in i-photo. I need help gettygetting them oon fce facebook. I had better end this comment befoe I lose everything.
W,J,/o Creative Design and Developmenl Prototype and Engineering Models Parts Made To 0rder
On ttre square sided tower, it helps to really pat the rim and also to shake the mold up and down so that you can see and feel the sand rise in ttre mold. Push ttre sand back down and shake it
-- '-'-----rf,p-age:rtr'*' Doi*g:t+]is a-few times will loasel}*.it"-e*ou6ih-€or*tJae*---- sand. to come out when you are read.y. The pistons realIy" help on these molds.
ftre eight sided cone, #1- is one of the hardest, especially to get the thin I'beakrr sectj-on out in one piece. The bulk of the sand comes out easily. It is the rrbeakrr that breaks off and stays in the mold.. Pat,ting the mold in the area of the rrb.ek, helps. Experiment with packing pressures and. techniques and also with patting the mold
The cone #3 will also give trouble with the sand breaking off near the tip. It takes good packing in ttre beginnj-ng near the tip to get it to come out weII.
Ttre stairs #5 need to be tapped on the side so that ttre sand actually breaks away from the mold before you try to push it out. They definitely need the pist,on.
fhe ring pieces, M aud the tops for #6 and # 7 come out nicely if you pack ttrem well, and then push them out wj.th the pistons.
You will have to practice wj-th all of ttrem, but I donrt think Etrat'lrou tLll ffi€=-anf 'reuI trouble with alTv*of theni, except the beak on #1.
The digging tools for the doors and windows require a light scrapping action toward the center. The edges will crumble and be rough no matter what you d.o. Cutting the slits at the top of the turrets is done with many light strokes, using downward pressure.
If you have any qu
CR4 ADMIN - personal contact info removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
07/16/2012 12:38 PM
Hit the wrong item. Perhaps this would save a lot of time. Still want to get my idea off the ground though.. I was close to Riley Lohr's first page on his work. Got to get going with the day's activities.
07/16/2012 2:12 PM
Besides watching motor cycles zoom by our house while making the bed, this is all part of the day's activities, incidently, I also gaze on my getting in shape for my partner's chess move by looking at the two boards I have set up for the "A Champion of the New Mllenium". I can follow the Grunfield Defense for about four moves and then, my goodnes, here comes a comment that says what happens if instead of g6 a move of Bf5 changes the game entirely. I had better get back to getting breakast now. Sorry.
07/12/2012 1:17 AM
Sand
07/12/2012 1:53 PM
I have to get going with the day's activities. Sand of course (see previous comment) I tried to get a picture from the beach. Perhaps latter.
07/12/2012 2:20 PM
So you are attempting to corner the market for sandcastle construction by kids who have no imagination or skills?
(Sadly an all around likely and rapidly growing target market I might say.)
07/12/2012 4:29 PM
Sand, making towers, walls, stairs, corners, either cylindrical or rectangular, cones, base for tower (larger than the rest)
Good Answers: 110
07/09/2012 3:07 PM
Your picture illustrates the fundamental problem you are trying to overcome with a push stick. The mold is bad. You can see that is has negative draft, because the open edge is deflected inward (relative to the closed end -- upper end in this picture). Thus, the sand will tend to stick in the mold, and the deflected edge will drag on the sand as the mold is removed -- a definite problem.
Mold makers have been hung for less.
Another fundamental problem: the push stick (with its attached platen) would need to be placed in the mold before filling with sand. That presents problems in handling the mold. In an ordinary sand mold, the mold is used just like a bucket. You place it on the sand, open end up. Then you shovel sand in (or fill it by hand). Having a stick coming out the bottom causes a problem with getting the mold to stand upright.
The structure of a sand castle is improved if each element is wider on the base, so a tapered mold makes a better castle, and also allows for the easy release that kids have been experiencing for generations.
Was there some problem you were trying to overcome when you imagined the need for a push stick?
Given that there are already so many sand castle making sets on the market, perhaps it would be better to give kids nothing to make sand art. Then they would use their creativity to come up with more interesting shapes.
Think big. Drive small.
07/10/2012 2:19 AM
Trying to get Riley Lohr's letter, the one who made these sand mold's. He describes the technique that he developed. Will try another time.It will tie in what you are talking about.
07/10/2012 7:11 PM
That's driving the point into the ground!
07/10/2012 11:56 PM
You are probably right. The only way I think out of thie is to play in slow motion a video of the original comments from Riley Lohrs's original efforts along with a recent version of what various contributors might provide and then use various formulas and insight to come to some conclusion. This is suppose to be Research so someone very very bright could probably fit well into this. Not me. I did pay Riley $300 to develop a sand castle mold about 30 or so years ago. I would like to know my money spent was worth it. r
07/13/2012 2:26 AM
About 30 or so years ago I had a great (?) idea of using sand molds to make a sand castle. Then, I tried to imagine what would it look like. So I went to the library and found drawings of all kinds of sand castles. I then tried to use the various drawings and pictures to do my own version. I found somebody who agreed to give it a try. In order to do this request he thought he would need push rods. This push rod consisted of a plastic plate cemented to a plastic rod. (One of my comments show part of a letter that he sent me, in order to understand how all this could be done.) The plate is placed inside the roof which is then upside down.(The mold, that is,,,, The attached rod then goes thru an opening, protruding outside and the rest is obvious. You would think. It is quite an art. I do believe that the push rod was his idea. It was more than thirty years ago that this all happened. I am not ssre how this will all pan out. I am not in any positon right now to spend any money on this. As you can see, there are a lot of gyrations of how to perfect all of this. We are in a computer age so amazing things can happen. I am sure that thru the studies of fluid dynamics, aerodynamics, you name it, the shape of the molds could be worked out so nothing sticks. This all could be compared to designing a bette mouse trap. Then there is the bucket and Moon Sand.
07/07/2012 6:28 PM
07/12/2012 2:17 AM
Thanks. I will try to get my wife to watch all of this tomorrow.
07/07/2012 6:37 PM
So whats you fascination with the need to over engineer simple house hold/kids toys items?
That vast majority of your threads and posts seem to always revolve around needing the mechanical and structural or similar specs to common items and materials that most kids could figure out as to which is best or is at minimal more than adequate to do the job at hand.
07/08/2012 1:44 AM
I thought of the idea of sand molds about 30 or so years ago, thought it was a good idea, tried it out, broke all the push rods and then packed it all in a box and did nothing about it. I learned that my idea was nothng new, the box containing all the parts just lay there for years. I did take drafting, statics, metalurgy, physics and then ended up with a degree in chemistry. Now that I am retired I thought, what the heck, I will give another try for the idea. I found the file with patents, letter from my patent attorney, pictures from a day at Santa Cruz and am getting advice from a computer guro. I have been reading some of the comments from engineers on other subjects and am begining to show more interest in what is somewhat more advanced. I wouldn't mind getting into a discussion of our heating system. It is somewhat faulty; the heat is well distributed around the original part of the house but with an addition of connecting a playroom to the main part we still have the same type of furnance. Lots of ducts going all the way past the kitchen area to the end of the play room. So the heat is not well distributed further down.. To solve the problelm someone sugested that the ceiling at the further end of the play room could be opened and the heat could revolve around and mix. Little complicated.
07/08/2012 6:37 AM
Tell me, really.
Is this thread more vexing than all the truly imbecilic questions asked here every day by random people wanting instant knowledge?
07/08/2012 7:00 AM
Depends.
When a 6 year old of average intelligence could figure it out which material is stronger given their limited life experience, powers of observation, and the use of their two hands over someone who has been vexed by this problem for 30 years yet wants to patent the concept of a plastic form, a plate, and push rod to make sand castles how would you rate the question?
Personally I think I have been rather nice so far really.
07/08/2012 1:15 PM
No big deal. Please read my reply to #3.
07/09/2012 10:11 AM
Please read comments to Tornado: #9 reply to #7. Just put "Stresses in Silos" derived from another comment on all this in my Sand Castle binder. Another day, our neighbor accross the street just arrived. He is putting a newer house inside the original house. It is interesting to watch during the day between various jobs around our house.
Good Answers: 102
07/07/2012 11:51 PM
Material selection for this is easy.
Just use whatever you have lying around in your shed.
Gold bars would work just fine too. No need to think too much or to buy anything special.
07/08/2012 2:15 AM
!/2" or so wooden dowel, perhaps with a drawer knob mounted on one end.
07/08/2012 3:20 AM
Please read my comment to Tcmtech. Is there any one other than my pepetual sand castle project that I should be reading about and who knows might even contribute a comment? I was quite impressed with the inspiring talk by a Civil Engineer who gave a good talk to our high school (class of 1950 for me). I once wrote a paper on the Golden Gate Bridge and got a good grade on it. I think Straus was the boss. Actually my degree is in chemistry. Thank you for your last comment (see above) I still want to pursue the sand castle project, however.
07/08/2012 5:07 AM
Okay then just stop by your local hardware store and buy a common 1/4", 3/8" or 1/2" socket extension bar of what ever length you need.
I have seen them in sizes all the way up to 24" long and I can guarantee that a 1/2" x 24" socket extension bar couldn't be bent or broken by pushing on it with all the strength you could ever humanly generate by hand or even foot power.
They are heat treated high carbon tool steel with a chrome plating if you need a metallurgical analysis as well.
(Seriously now. My six year old niece understands the concepts of materials well enough to figure out that a metal rod would be far stronger than a wood or plastic one of the same size without needing advice from an engineer.)
07/09/2012 10:33 AM
Sorry about the spelling of my attempt to spell correctly. It is spelled perpetual so says the dictionary. Now back to the day's activities. Pulling weeds, putting dishes away, etc.
07/24/2012 4:17 AM
This might be of interest if it could be enlarged.
Good Answers: 110
07/24/2012 3:37 PM
You could just reference the patent number, and then we could read it easily on line.
07/24/2012 8:33 PM
I am not sure how to reference the patent number. Our computer guru will visit us soon. Perhaps he can. I have the letter from the patent attorney who lists about nine different patent No.'s. The most pertinent reference is the patent to Noyes No. 1,248,532. Time for the news.
07/24/2012 8:39 PM
The number is 1,248,532. The patent discloss a mold having a partially open top which is ueful in forming a house from sand.
07/08/2012 2:41 AM
Well, I found this for cake decorating: http://www.bakedecoratecelebrate.com/techniques.cfm?cat=8 Seems like the same principle.
Plastic and wood can easily be cut to length. Wood is biodegradable. So, for a beach sandcastle, use wood. For something that is going to be in a museum use plastic. If you want your sand castle to be more expensive, use gold.
07/08/2012 6:34 AM
Paint roller handles should work.
3-piece Wood Extension Pole | Benjamin Moore
07/08/2012 7:30 AM
It's just like racing cars..."How fast do you want to go? How much money do you have?"
If you want to contribute to the steel industry buy stainless, if you are a bit more conservative, use a chunk of scrap wood!
07/08/2012 12:00 PM
According to Heidi's posting history, this is the 10th thread on the same subject, in the past year and a half.
07/24/2012 4:53 AM
I would skip the push rod idea altogether, just use a thumb or finger to push through the hole in the outer mold, and then lift the inner plate away.
Register to Reply 50 comments
Heidi (21); K_Fry (2); KeepItSimpleStupid (1); lyn (7); pantaz (1); redfred (3); SolarEagle (1); StandardsGuy (2); tcmtech (6); Tom_Consulting (1); Tornado (2); Wal (3)
