Previous in Forum: Help and Solve the BTU Problem   Next in Forum: Silicone-like Material
9 comments
Cooling Tower
07/09/2012 3:29 AM
how we can calculate losses of water from cooling tower.
Re: cooling tower
07/09/2012 3:36 AM
Fit a level control on the tower pond, a solenoid valve driven by it on the make-up line and a totalising flowmeter in the make-up line itself. Read the flowmeter at intervals and record.
Re: cooling tower
07/09/2012 3:43 AM
I think they want the calculations, formulas and examples, with pictures. Along with a step-by-step breakdown of your thought processes during the calculations.
Re: cooling tower
07/09/2012 3:48 AM
Too bad - especially as practically no-one else does it like that.
Good Answers: 38
Re: cooling tower
07/09/2012 4:46 AM
measure water coming in and measure water coming out
Re: cooling tower
07/09/2012 6:01 AM
Evaporating water accounts for about 1000 Btu/lb. A surplus of water ("bleed-off") should also be provided. The surplus amount varies with the mineral content of the water and any treatment, but a rule of thumb is that it can equal the amount evaporated.
Good Answers: 38
Re: cooling tower
07/09/2012 8:08 AM
Can you be a little more specific VK ?
Cooling towers losses include evaporation, blowdown and drift.
Losses can vary with wind speed, operating temperature and percent blowdown selected.
Where will this tower be located and what, exactly are you interested in ....???
Re: Cooling Tower
07/09/2012 8:58 AM
In the customary USA units:
M = Make-up water in gal/min
C = Circulating water in gal/min
D = Draw-off water in gal/min
E = Evaporated water in gal/min
W = Windage loss of water in gal/min
X = Concentration in ppmw (of any completely soluble salts … usually chlorides)
XM = Concentration of chlorides in make-up water (M), in ppmw
XC = Concentration of chlorides in circulating water (C), in ppmw
Cycles = Cycles of concentration = XC / XM
ppmw = parts per million by weight
A water balance around the entire system is:
M = E + D + W
Since the evaporated water (E) has no salts, a chloride balance around the system is:
M (XM) = D (XC) + W (XC) = XC (D + W)
and, therefore:
XC / XM = Cycles = M / (D + W) = M / (M - E) = 1 + {E / (D + W)}
From a simplified heat balance around the cooling tower:
(E) = (C) (ΔT) (cp) / HV
where:
HV = latent heat of vaporization of water = ca. 1,000 Btu/pound
ΔT = water temperature difference from tower top to tower bottom, in °F
cp = specific heat of water = 1 Btu/pound/°F
Windage losses (W), in the absence of manufacturer's data, may be assumed to be:
W = 0.3 to 1.0 percent of C for a natural draft cooling tower
W = 0.1 to 0.3 percent of C for an induced draft cooling tower
W = about 0.01 percent of C if the cooling tower has windage drift eliminators
Concentration cycles in petroleum refinery cooling towers usually range from 3 to 7. In some large power plants, the cooling tower concentration cycles may be much higher.
(Note: Draw-off and blowdown are synonymous. Windage and drift are also synonymous.)
for metric....
Re: Cooling Tower
10/10/2012 1:03 AM
CR4 Admin: Spam: This post was modified because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Re: Cooling Tower
10/10/2012 1:09 AM
Approx. 1 pound of water for each 1000 Btu of heat rejected, plus a similar amount for bleed-off or blow-down (or whatever you call it), plus maybe 2% for drift (droplets that blow away).
Register to Reply 9 comments
bancream (1); Epke (1); lyn (1); MJCronin (1); PWSlack (2); SolarEagle (1); Tornado (2)
