Previous in Forum: Detail Procedure for Design Mcc Panel   Next in Forum: Un Earthed & Earthed cable
KW & PF
07/11/2012 1:04 AM
An alternator is designed at 1746KVA at unity power factor. what will be its Maximum rated KW rating at 0.9pf.
An alternator is designed at 1064kw at 0.8pf. What will be its maximum rated Kw at unity pf.
Thanks in advance.
Re: KW & pf
07/11/2012 1:30 AM
1746 KVA x 0.9 pf ≈ 1571 KW.
1064 KW ÷ 0.8 pf = 1330 KVA = 1330 KW (if pf = 1).
Good Answers: 131
Re: KW & PF
07/11/2012 7:35 AM
Homework?
Re: KW & PF
07/12/2012 1:22 AM
You should consider the rating of the prime mover too.
pnaban
Re: KW & PF
07/14/2012 2:54 AM
formula is as follows
KW RATING = KVA RATING INTO PF
THANKS
Re: KW & PF
07/14/2012 3:13 AM
Actually, KW = KVA × PF.
gajendrasingh01 (1); PeterT (1); pnaban (1); Tornado (2)
