Previous in Forum: What Model Contractor Goes to Disconnect My Generator From Home Distr.Panel?   Next in Forum: KW & PF
Detail Procedure for Design Mcc Panel
07/10/2012 11:46 PM
i am plc panel designer.can u tell me to detail procedure to design MCC panel?
Re: Detail procedure for design Mcc panel
07/10/2012 11:57 PM
What procedure do you use to design your plc panels?
That'll probably work for MCC panel too.
07/11/2012 4:52 AM
THANKS A LOT
Reply Off Topic (Score 7)
07/11/2012 1:35 AM
There is no one detailed procedure for this; it depends on any of the several basic approaches to building an MCC, and on the manufacturer of the components.
Even then, a detailed procedure would amount to a book, which is impractical to give in a few forum posts.
07/11/2012 3:18 AM
Asking Anonymous Poster #1 would be the first step in any procedure, as it is far easier to clone what has been done before rather than start with a blank piece of paper.
Re: Detail Procedure for Design Mcc Panel
07/14/2012 6:02 AM
An MDB will require more in layout considerations than a PLC or an MCC panel.
Commonly you begin with completing your wiring diagram (your design), then your materials list. After you have all the required components with their data sheets, you arrange your panel with respect to your components dimensions, finish your layout, final check, and send for fabrication.
07/14/2012 6:21 AM
Dear sir
i want to know how to slect star delta contactor for the motor.if you observed siemens
3vt series its mismatching with current calculated by the formula.i want to know exact process for slection of star delta contactor slection.
07/14/2012 8:50 AM
Star Con. rate at 38% FLI
Delta and main rated at 65% FLI
You can download starters' catalogue from manufacturers' website to look up products by reference with respect to motors rating.
It will be a little off hand calculation because not all ratings are readily available in the market, and in that case, you will be pointed for a next step up.
Remember to identify between AC1 and AC3 ratings.
ATUL (2); AW (2); lyn (1); PWSlack (1); Tornado (1)
