Previous in Forum: Water Pressure Pump - How to Adjust Water Pressure   Next in Forum: When Synchronous Motor is used Over Induction type Motor
Help in Diesel Engines
07/19/2012 1:56 PM
i have 2 questions in diesel engines :1) i want to specify the combustion process stages ( delay period , uncontrolled combustion , controlled combustion , after burning stage ) on the crank shaft angles coz i read different angles in many sources so i want exact angles before and after the tdc ?
2) is there any difference between knocking and detonation and what is the most important factor that causes it ?
Re: help in diesel engines
07/19/2012 2:02 PM
Each engine will have different timing sequences. You'll have to look at the individual engine specifications.
Look up pre-ignition. Knocking and detonation are the same thing.
07/19/2012 3:45 PM
thanks lyn but i want to know if there is specific angles preferred or something like that ,
and one more question is it correct that 2 stroke engine is more powerful than 4 stroke engine at same rpm
07/20/2012 3:24 AM
A 2-stroke has twice as many power strokes per revolution than a 4-stroke, through it is inherently less efficient per power stroke. It is not possible to generalise.
Register to Reply 3 comments
islam.aboauf (1); lyn (1); PWSlack (1)
