Previous in Forum: ACB Interlocking   Next in Forum: Thyripart Excitation
Under Voltage & Over Voltage Protection
08/16/2012 7:54 AM
Why there is no under voltage and over voltage protection
in lower voltage power distribution like
over current,earth fault protection?
Re: Under voltage & Over voltage protection
08/16/2012 8:30 AM
Is it because whoever designed the system determined that there is no need for them?
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
Re: Under Voltage & Over Voltage Protection
08/16/2012 5:52 PM
There are under & over voltage sensors around which when incorporated into your Main Switch Board, UPS & Generators controls will protect your equipment.
There are also Voltage regulators available to trim over voltage and UPSs support under voltage.
Regards,
Sapper
It's all about the Boom! - MythBusters
08/17/2012 7:30 AM
Such protections are normally provided at the LV sub stations of the Utility supply systems/ Industries /Commercial complexes etc.Hence, same is normally not required at the down stream distribution net work due to economic reasons.
However, if the concerned appliance is expensive/critical (eg.medical appliance),necessary protection is ensured through UPS by making uninterrupted and quality power supply available to the device.
Learning is a never-ending process.
Good Answers: 15
08/17/2012 9:45 AM
By controlling the HV you control the LV so its in place.
A supply company has limits within which it must supply - voltage Hz etc.
Good Answers: 170
08/20/2012 11:49 AM
Not warranted on a cost-benefit analysis. But, having said that, for important equipments it is normal to provide the above protections too.
electricalexpert65 (1); PWSlack (1); Sapper (1); silverfox (1); spradhan (1)
