Previous in Forum: Magnetic Starter for Air Compressor   Next in Forum: NGR Closing of Multiple Generator
8 comments
The Procedure of Calculating the Load Balance for an Offshore Drilling Unit
09/03/2012 5:21 AM
Before you decide the numbers of Generator and its volume for designing the drilling units, you must calculate the Overall Load Balance or Load Consumption for it.
But after I collect the power data of every consumer, how can I start to calculate the Load balance? I know the difference between Load factor, Use factor and Diversity factor of a motor, but which one I shall use for my calculation. For the time being I just use Load factor (according to various working conditions) to calculate the power "needed" of a motor, then I apply a certain use factor for deciding its time of use(during that condition). I am not sure if I have done right.
Moreover, could anyone suggest me the load factor and usage factor list for a Submersible drilling units? Thank you so much!
Re: The Procedure of Calculating the Load Balance for an Offshore Drilling Unit
09/03/2012 9:53 AM
How did you get this job?
I think you should write a book on "How to get hired when you kow nothing about the job you want".
Just pretend it's a house.
Load Calculation - EERE - U.S. Department of Energy
submersible drilling rig: Schlumberger Oilfield Glossary
09/03/2012 1:13 PM
There may be a Code governing this; if so, you need to follow it.
If load factor and use factor are already in your calculation, it seems that diversity would be redundant; but it depends on what any applicable Code says.
Your load calculation method should account for starting the largest motor while all other possible concurrent loads are also running. The key word is "concurrent."
09/03/2012 1:19 PM
I don't know about offshore stuff.
When I built equipment we had to supply enough power to provide the full FLA value for everything that could possible be starting, or running. (OK, I didn't build it, I was just a useless engineering manager)
09/03/2012 2:20 PM
I've got one up on you. I have actually built such stuff (UL508 panels) with my own hands, in addition to being a useless engineering manager!
09/03/2012 2:35 PM
I did some work once. It wasn't for me. I finally learned that if you can't dazzle 'em with brilliance, baffle 'em with bullsh*t.
Your talents are obvious, based on your responses here.
I have never liked electricity. I don't trust anything I can't see.
I'll do 120v receptacles and that's about it.
09/03/2012 3:17 PM
Useless Engineering Manager should be capitalized. In a Peter Principle world, it is obviously a bona fide job title.
09/03/2012 11:02 PM
Electricity is dangerous, yes. Over the last ten years I have spent quite some time around captive wolves. They can both be dangerous when you become complacent, or when there's a short in your test leads that you didn't notice! (that say you have zero volts at a location) I sometimes work for a property investor who said he once rewired an entire household breaker box without shutting anything off. Nope. Not me! I'll have Edison shut down the mains before I install a new box.
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Marine Engineering - New Member Engineering Fields - Aerospace Engineering - Aeromarine Vehicle Engineer
09/04/2012 6:22 PM
I believe this Offshore Drilling Unit will be classified by one or more of the classification societies such as: American Bureau of Shipping, Lloyds Registry of Shipping, Bureau Veritas, Det Norske Veritas (DNV), etc. Please find out whose will be classifying and surveying the construction and then get their electrical design requirements.
I pray you are not working on an Offshore Drilling unit for the Arctic Ocean.
Register to Reply 8 comments
Gannet (1); lyn (3); Tornado (3); tundrawolf (1)
