Previous in Forum: Relay Protection for Motor   Next in Forum: Neutral Size Compared to Phases
16 comments
OLR Setting
09/08/2012 5:30 AM
dear all
33Amp three phase motor starter . In OLR ( overload relay ) howmach overload current need to set.
Good Answers: 34
Re: OLR setting
09/08/2012 6:03 AM
Look on the name plate of the motor, for full load current & set your OLR accordingly.
Re: OLR setting
09/08/2012 8:09 AM
10 % Generally
India - Member - New Member
Good Answers: 164
Re: OLR setting
09/08/2012 11:19 AM
Oops, wrong answer. No 10% or any other factor is applicable.
Joshi's answer is correct, you should set it at the rated current of the motor (if it is a DOL starter and the FLA is passing through it).
Re: OLR setting
09/08/2012 10:27 PM
Not quite. If the OLR is in a different ambient temperature location from the motor, some adjustments may be appropriate. With fixed heaters, this can mean a size or two up or down. With adjustable relays, this may mean ± some similar amount. One case of special interest is fan motors in blast freezers at -35°C. The extra cold air can allow actual amps to be something like 20% above normal FLC.
Good Answers: 164
Re: OLR setting
09/09/2012 7:19 AM
Most IEC devices available in India are ambient-compensated. In fact the good ones are "under-compensated" by 0.4% per °C to take into account the difference in thermal mass between the OLR and the motor. US-style eutectic alloy relays are not ambient compensated as you rightly point out.
Re: OLR setting
09/09/2012 10:34 AM
I see how an ORL can be ambient-compensated for its own ambient, but not for the motor's ambient if different. The IEC doesn't address this?
Re: OLR setting
09/09/2012 10:47 AM
Please revisit #6
Re: OLR setting
09/09/2012 4:31 PM
Irrelevant. I am not talking about the thermal mass of the motor; I am talking about quite different ambient temperatures at the OLR versus the motor.
Good Answers: 164
Re: OLR setting
09/09/2012 11:19 AM
i believe it does. Hence the under-compensation, which actually is implied in IEC 60947-4 vide this figure...
The non-trip/trip gates are 1.05/1.2 at 20°C, and 1.00/1.2 @ 40°C. This, to me, allows for the higher thermal mass of the motor. If the relay wasn't ambient-compensated, it would trip unnecessarily at a lower current, over-protecting the motor. i do believe that the ambient compensation is actually to prevent nuisance tripping of the relay, if they are both at the same ambient. If the relay is in a controlled ambient say 20°C, and the motor is toiling at say 40°C, there may be an unprotected zone (1.00 - 1.05) but this is statistically ignorable in view of the better performance in most other conditions (both at same ambient, motor at different but not too high an ambient, etc). Just my opinion.
Re: OLR Setting
09/09/2012 6:36 AM
+20% of FLC is acceptable for c class insulation. also you have to mind the connections
* or D
love4everyone
Good Answers: 170
Re: OLR Setting
09/09/2012 9:24 AM
Grossly incorrect! Only Joshi & KVS are correct. The OLR must be set to - not more than - the rated full load current of the motor. However, one can set the OLR to less than the FLC of the motor, if the motor is oversized.
Re: OLR Setting
09/09/2012 9:56 AM
RTFM.
Re: OLR Setting
09/09/2012 10:12 AM
The MANUAL is not always, the gospel truth. There are always exceptions to that.
Re: OLR Setting
09/09/2012 4:57 PM
You can set the overload to whatever you want, but if you set it to more than FLA you are going to shorten the life of the motor if it runs above FLA.
Re: OLR Setting
09/09/2012 7:15 PM
Not necessarily, as in the blast freezer fans described previously.
OLR Setting
09/10/2012 7:35 AM
refer
Table 430-148 (From 1999 NEC) or
Table 430-150 (From 1999 NEC)
Register to Reply 16 comments
Anonymous Poster (2); electricalexpert65 (1); eltech (1); Joshi (1); karanthsp (1); kvsridhar (3); Muthuvel (1); sohail0110 (1); Tornado (5)
