Previous in Forum: Diesel Engine With Hopper Cooling System   Next in Forum: 3 Phase Fan, Large Industrial Model, As Generator
10 comments
Long Running Hours Diesel Engine
09/08/2012 11:24 AM
what must i do if i have a plan to make a diesel engine can work 1000Hours with no stop the engine.... is this possible ???
if possible, what must i do ???
this diesel engine for diesel generator at remote area purpose.
Good Answers: 34
Re: long running hours diesel engine
09/08/2012 12:26 PM
That makes it running, continuously for 42 days. Surely doable. It depends on your abilities, infrastructure & so many, many, ---other things. Good luck! You are welcome to re-invent the wheel. God be with you!
09/08/2012 1:53 PM
Well first I would consider the size of the fuel tank. Next I would consider why you will need to be away from civilization for as much as 42 days and seriously reconsider the situation. I would particularly wonder if 42 days is enough time and if you really need to run a diesel engine all of that time. Isolating yourself from civilization is so much easier when you don't use any of the comforts of civilization.
Re: Long Running Hours Diesel Engine
09/08/2012 7:29 PM
The most important issue will be oil treatment. A centrifuge or special filtration system can help there; an extra-large oil sump can also help.
The fuel injection system must be of a kind that does not require frequent adjustment. Bosch type probably good; camshaft-driven unit injectors probably bad.
Make your fuel tank large enough, or at least able to be replenished with no engine interruption.
09/09/2012 1:12 AM
When they say "continuously rated",according to codes/rules/regulations, how many hours an engine/alternator/motor/transformer/compressor can run continuously?.
pnaban
Reply Score 1 for Off Topic
09/09/2012 1:30 AM
the united states navy has all the information you need.
09/09/2012 6:24 AM
Can you please quote same?.
pnaban
09/09/2012 8:16 AM
sorry, i don't know how to access the information you need.
others on this site can help.
09/09/2012 6:07 AM
yes you can ,if your engine is in good condition specially the head gasket and valves(not over heating ) and having a efficient cooling system and fuel injection pump.
just you have to maintain the fuel and the normal checkup of lubricant and temperature.
wish you a good luck
love4everyone
02/09/2013 12:21 PM
Dear Friend, For your question the Answer is YES.
But you, have to take steps, like to fill up- diesel in the fuel tank, while in operation, replenish Engine oil for every 200 Hours. Better you have two Air-Filter in parallel etc.
DHAYANANDHAN.S
02/09/2013 9:52 PM
Condition monitoring including oil conditioning/filtering,lubrication,heat removal or reducing load if overheating occurs,duplication some parts etc might help
pnaban
dhayanandhan (1); durtieduck (2); Joshi (1); pnaban (3); redfred (1); sohail0110 (1); Tornado (1)
