Previous in Forum: Problem In Gas Supervision Contractor of 66KV SF6 Breaker Make ABB   Next in Forum: Over Heating of Neutral Earthing Strip of 1500kVA DG Set.
corona discharge
09/12/2012 9:35 AM
what is the reason behind noise (corona affect) in ac transmission lines
Pathfinder Tags: 123
Re: corona discharge
09/12/2012 9:40 AM
When an electrical discharge takes place in air, inevitably some of the energy is dissipated as sound and light.
Good Answers: 34
09/12/2012 9:58 AM
It is explained in detail in this link:
http://en.wikipedia.org/wiki/Corona_discharge
09/13/2012 1:17 AM
i'm not an electrician, but i've seen this effect on high voltage wires near a cement plant. the insulators were white from cement dust.
India - Member - Proud to be INDIAN Engineering Fields - Power Engineering - New Member
09/15/2012 7:48 AM
ionization
you need to go, to get something
Register to Reply 4 comments
durtieduck (1); Joshi (1); PWSlack (1); sharath4 (1)
