Previous in Forum: BOE Exams   Next in Forum: Gravity Damper Capacity Calculation
Feedback Signal from a Control Valve
09/16/2012 3:16 AM
Dears
how can i receive a feedback signal from a control valve using SIPART ps2 . showing on my SCADA the actual position for the valve?
Pathfinder Tags: control valves
Re: feedback signal from a control valve
09/16/2012 9:53 AM
Well if you identified something about the control valve (fluid controlled, pressure range, control mechanism, manufacturer, etc.) then we might be able to guide you to an efficient way to obtain your feedback. Come to think of it, you don't even ask for an efficient method. You just asked for a possible method. I cannot draw very well but I've always admired Rube Goldberg's work.
Glue a protractor to the valve shaft and focus a web camera onto a pointer that indicates the shaft position. Send this image to a musical conductor of your local Baroque music ensemble. He will use the degree shown in the image to select the tempo and musical piece to be played by the orchestra. This music will then be piped to a musicologist with a stop watch to identify the musical composition and the beats per minute used in this performance. He'll write a review of the performance in your local paper and its web review. A grad student will copy the web review to their blog. You will read the review and translate the review to the valve position and type this value into your SCADA system.
(Just trying to add some humour.)
Good Answers: 176
09/16/2012 10:09 AM
There are two means to read position
1) analog output 4-20mA representing position
The LY module is an analog output module option for the PS2:
2) Read the primary HART variable which is position in units of percent
Re: Feedback Signal from a Control Valve
09/17/2012 3:33 AM
The position of the valve is of less value than information about what is happening to the process variable that the valve is being used to control.
Register to Reply 4 comments
Iris (1); Joshi (1); PWSlack (1); redfred (1)
