Previous in Forum: Selecting a Brake Rectifier?   Next in Forum: Shorting Resistor
14 comments
Substation IPS
09/17/2012 1:52 AM
What is the meaning of acronym IPS?
Re: Substation IPS
09/17/2012 1:58 AM
Here are some possibilities (from AcronymFinder). Several might apply.
Re: Substation IPS
09/17/2012 2:14 AM
Thanks very much Tornado, but i'm asking for the IPS that we are using most commonly in substation installation.
malec.
Re: Substation IPS
09/17/2012 3:23 AM
Take Tornado's link in #1↑, find the candidates, and cross out all thse that do not apply, then.
Re: Substation IPS
09/17/2012 3:11 AM
Iron pipe size....
Re: Substation IPS
09/21/2012 2:51 AM
Thank you so much SolarEagle.
God bless!
malec
Re: Substation IPS
09/17/2012 3:24 AM
No. Intermediate Pumping Station!
Good Answers: 34
Re: Substation IPS
09/17/2012 4:08 AM
IPS Tubes are used for Sub-Station buses. The IPS Tube fittings are designed to see that sharp edges are avoided so that Corona activity is minimized.
Good Answers: 170
Re: Substation IPS
09/17/2012 9:18 AM
International Pipe Standard
Re: Substation IPS
09/17/2012 4:03 PM
Ingress Protection Standard possibly?
Your guess is as good as ours based on the little information you have given - it could be any number of acronyms, all of which could relate directly to substations.
Can you provide more information?
Re: Substation IPS
09/21/2012 3:05 AM
Thanks very much. I think this is most nearest when we talking about power substation.
Thanks, for your answer.
malec
Good Answers: 170
Re: Substation IPS
09/21/2012 9:43 AM
Your acknowledgement is wrong! In outdoor sub-stations, they generally use a tubular aluminium bus. The sizes of this hollow tubular Aluminium Bus bars are covered in a standard called the International Pipe Standard. For example, in a 66kV Switchyard, we may use a 4" IPS Aluminium Bus, which means that we are going to use a 4" Aluminium bus, whose specifications are elaborated in the International Pipe Standard or IPS.
Ingress Protection, is generally specified only as IP and not as IPS and it will have significance in Indoor Sub-stations, for example, in Switchboards.
Re: Substation IPS
09/24/2012 11:00 PM
okay, thanks very much for your correction and for this information.
malec
Re: Substation IPS
10/13/2012 6:48 AM
OK IM SORRY, YOUR ANSWER IS CORRECT AND JUSTIFIABLE. THANK YOU VERY MUCH FOR THIS INFO AND FOR YOUR EXPLANATION.
MALEC
Good Answers: 244
Re: Substation IPS
09/18/2012 8:16 PM
It is for 'Instant Power Supply'. IPS is similar to UPS (Uninterruptible Power Supply). The major difference between UPS and IPS is that UPS has zero switching time (i.e. no interruption of power) while IPS has longer switching time (i.e. momentary interruption of power).
- MS
Register to Reply 14 comments
electricalexpert65 (2); jack of all trades (1); Joshi (1); malec (5); msamad (1); PWSlack (2); SolarEagle (1); Tornado (1)
