Previous in Forum: Is it Possible to Make Free Energy Device?   Next in Forum: Reversing Polarity
Is it Possible to Make Solar Module 240 Volts to 280 Volts?
09/27/2012 2:24 PM
i have an best to get more energy efficient devices when availbility of 240-280 volts solar modules. if yes give me details
Re: Is it Possible to Make Solar Module 240 Volts to 280 Volts?
09/27/2012 2:31 PM
Check with solar module makers.
09/27/2012 4:29 PM
Just series together enough cells. Sheesh.
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
09/27/2012 5:42 PM
Are you talking about the DC side or the Inverter output which you plug your appliances in to???
If you want 240-280VDC...check with your installer and get them to see if the inverter will use that voltage.
If you are referring to 240VAC from the inverter where you plug your appliances into ....The answer is NO...
If you dont understand what the difference is .... Don't play with it...
Regards,
Sapper
It's all about the Boom! - MythBusters
Register to Reply 3 comments
lyn (1); Sapper (1); Tornado (1)
