Previous in Forum: Is it Possible to Make Solar Module 240 Volts to 280 Volts?   Next in Forum: Transformer Earth Shield
20 comments
Reversing Polarity
09/27/2012 6:35 PM
I am trying to figure out how I can reverse the direction of a rotisserie motor so that it can run both directions. Is there some kind of circuit thingy I can wire in or should I just buy two engines. Basically, I want my engine to run forward for like one minute and then backwards for like one minute.
Re: Reversing polarity
09/27/2012 6:57 PM
I can't imagine why you would want to do this. Especially once a minute.
BBQ Rotisserie Variable Speed Reversible Brushless Gear Motor 10 .
Did you search for↑
09/27/2012 7:22 PM
If it burns, you can uncook it?
09/28/2012 1:05 AM
yea totally. ....Science.
Good Answers: 69
09/28/2012 10:14 AM
Very funny, really.
I don't think reversing would make any noticeable difference in the chickens, except maybe catching the eye of the customer with a "more advanced, automated rotisserie".
Good Answers: 804
09/27/2012 9:00 PM
Most inexpensive small rotissserie motors are common Shaded Pole motors, and as such are not designed to run in reverse.
Larger ones, who knows? it will depend on the specific type of motor used. if it is from 1/2 to 3HP, I would consider using a 3 phase motor and a VFD, that way you will not burn up the motor by reversing it that often.
Re: Lyn's FleaBay post:
You would need to be in serious need to waste some money to put a BLDC servo motor on a BBQ rotisserie... but I guess at $140, it's less than my suggestion of a 3 phase motor and a VFD though.
09/27/2012 10:24 PM
You might be able to get two cheap ones and mount one on either side and weld them together, then use a relay with a timer to switch back and forth....Can you turn the rotisserie by hand easily in reverse? If not then maybe a ratchet assembly...
Good Answers: 140
09/27/2012 10:28 PM
You can buy cheap DC powered motors made for just this purpose. Reversing their direction is as simple as reversing the power wires going to it. A simple DPDT toggle switch can do what you want or you can use a couple of relays and set it up to do it automatically. Go check your local hardware store, I be you find one there for $20 or close to it.
09/28/2012 12:53 AM
Use 2 contactors with a change-over switch. In position 1 it will run in one direction and in position 2 it will run in the opposite direction but check whether the shaft mounted can cool in both directions.
pnaban
Good Answers: 804
Re: Reversing Polarity
09/28/2012 2:03 PM
I think if you were cooking something with an off-center mass, like a bone-in Prime Rib, you would want to center the meat mass on the spit, but that may end up allowing part of it to extend down too close to the heat. Reversing would allow for more even cooking with less risk of burning parts of it.
Mmmmmm... lunch time...
09/28/2012 2:15 PM
This would be handy if moving back and forth frequently between the northern and southern hemispheres.
09/28/2012 10:59 PM
Please , tell us what the motor model and brand is , serial number will be good too.
At last the rotisserier brand a model .
devitg
Good Answers: 42
09/29/2012 12:01 AM
I would be surprised if you are using the motors for cooking.
On one project I saw BBQ motors used on a timer for an automatic feeder.
AC BBQ motors are generally shaded pole, and they don't reverse.
However, I did once have a battery operated BBQ motor. It took two D batteries. If you put the batteries in backwards it quite happily ran in reverse.
Good Answers: 102
09/29/2012 12:14 AM
Here you go....
Just stick this between your motor and rotisserie.
This ones from a 4x4. You can get 10 forward speeds and 2 reverse speeds
You could even run 2 rotisseries at once if you use the second output on the transfer case.....
09/29/2012 2:19 AM
The rotisserie motor on my BBQ reverses everytime I shut it off and turn it back on. In that case a simple timing circuit would be all that is required TOF & TON
"No Matter Where You Go.............. There You Are!"
09/29/2012 3:11 AM
If your engine can run in revers then you can use A.C driver motor (V to F driver).
or you can use some timers and relaies.
09/29/2012 8:12 AM
Just rig up a windup spring on it...when it turns off the spring will turn it back...you didn't say how fast you wanted it to go! :-)
Good Answers: 102
09/29/2012 10:12 PM
Now that's smart mate! Inspirational....
If you don't mind I'd like to add another energy storage arrangement....
Instead of a spring to store the energy (I reckon finding a suitable spring and contriving a mechanical interface for it could be a little time consuming...), you could use a mass on a rope hanging off a winch drum on the rotisserie axle. Windup up, unwind down. A limit switch (or 2) operated by "cams" on the rope could provide the feedback for the motor run/stop control.
09/29/2012 6:28 PM
Nah, this is what you need
10/01/2012 1:09 AM
Have you considered a small reversing gear?
You probably already have a gearbox, adding one more gear between the two will reverse it, a timer driving a solenoid could switch between the two configurations, disconnecting power briefly during the change over ( parallel microswitches could easily achieve this by connecting power to the motor when the gears are fully engaged in either configuration).
10/01/2012 9:52 AM
Reversible gear motor, a DPDT latching relay and a 555 timer.
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
Register to Reply 20 comments
caeser (1); devitg (1); GW (1); JRaef (2); lyn (1); North of 60 (1); papabubblez (1); pnaban (1); Rixter (1); ronclarke (1); SolarEagle (1); Tom_Consulting (1); Tornado (2); Wal (2); WAWAUS (1); Waynethebrain (1); Yahlasit (1)
