Previous in Forum: Laser Distance Measuring Instrument   Next in Forum: What "Integral" Type Means in Flow Meter Specs
8 comments
Analog Signal
09/29/2012 3:11 AM
Dear all, Pls explain detaily,why the anolog signal using 4-20mA and Mention the application.
Re: Analog Signal
09/29/2012 3:56 AM
4-20mA is used because it's convenient, provides good noise and disconnection immunity and for historical reasons.
Applications? All and any.
Re: Analog Signal
09/29/2012 5:10 AM
Thnks,but can u say the PLC related application.
Re: Analog Signal
09/29/2012 5:18 AM
Any analogue measuring application in any process, say measuring ph in water treatment. The reading can then be used to control whatever is necessary to maintain the correct limits..
Re: Analog Signal
09/29/2012 7:41 AM
ok thnks dude
Good Answers: 34
Re: Analog Signal
09/29/2012 8:48 AM
I would never use such language, for venerable Del the cat
Re: Analog Signal
09/29/2012 7:18 PM
For PLCs, 4-20mA is probably still the most common input option for analog data. (Some PLC mfrs do offer specialized RTD or thermocouple input modules, and various other signal protocols.)
Re: Analog Signal
09/30/2012 5:30 PM
this is the most common input (4-20ma or 0-10v)
the applications are pressure transducers and thermocouples also its common in
flow.
love4everyone
Re: Analog Signal
10/01/2012 6:20 AM
...plus the use of a 'live zero' of 4mA means that readings below this can be used to provide an instrument fault alarm at some central control console.
Register to Reply 8 comments
dineshkv (2); Joshi (1); PWSlack (1); sohail0110 (1); Tornado (1); user-deleted-1105 (2)
