Previous in Forum: Clamp Design for Suspending Tube Steel   Next in Forum: Multi-Shaft Efficiency Comparison
10 comments
Velocity of Pressure Waves in Compressed Air Pipe Flow
10/05/2012 3:48 AM
It is understood that the pressure waves in piping travel at the velocity of sound in the medium. Medium is compressed dry air. From the formulae, I found that velocity of sound in gaseous medium is varying with temperature but independent of pressure.
1. Can we presume that velocity of sound at same temperature will be same for 0.5 bar vacuum and 25 bar g pressure?
2. If Piping consists of several bends, tee's, valves and change in cross sections, then will the average velocity of sound will reduce compared to straight piping?
Re: Velocity of pressure waves in compressed air pipe flow
10/05/2012 3:57 AM
10/05/2012 4:17 AM
1. Yes; 2. No.
Good Answers: 34
10/05/2012 6:07 AM
Can sound travel in vacuum?
10/05/2012 6:09 AM
Not in an absolute vacuum. Why the question?
10/05/2012 10:41 AM
Thanks PWSlack for confirmation.
But here Joshi's doubt is very much relevant. It is extremely difficult to create absolute vacuum. At high vacuum condition (below 0.001 mbar absolute pressure) will the velocity of sound be the same as ambient air pressure?
Reply Score 1 for Off Topic
10/05/2012 10:44 AM
You just moved the goal posts. In the OP, it was only 0.5 bar vacuum.
Good Answers: 34
10/05/2012 1:27 PM
OP's question "1. Can we presume that velocity of sound at same temperature will be same for 0.5 bar vacuum and 25 bar g pressure?"
What I would like to know is "will the velocity of sound be same for 0.5 bar vacuum and 25 bar g pressure?"
10/06/2012 10:22 AM
Yes Tarnado, you are right. I moved the goal post from 0.5 bar(a) to 0.001 mbar(a) pressure, just to better understand the theory behind it.
Theory says sound require a medium to travel, it can't travel in absolute vacuum. At the same time theory says velocity of sound in gaseous medium is independent of its pressure. Then at constant temperature velocity of sound should be the same at different pressures like 25 bar (a), 0.5 bar(a), 0.001 mbar(a) or even lower. So now the questions are:
1. Where is the cut-off point of gas pressure when sound will suddenly refuse to travel?
2. Is the sound waves travel through the molecules of gaseous medium which collied each other and transmit it and when collision reduces/stops velocity also reduces/ stops?
Good Answers: 137
10/06/2012 10:10 AM
I'd say that at a certain point of reducing pressure, the concept of sound ceases to be valid, as the molecules rarely collide. Not sure though about whether that's starting to happen at 0.001 mbar. I'd guess not as air at that pressure still contains about 3*1013 molecules per millilitre (or cm3). Avogadro's no. 6*1023/gmol/22.4 litre molar volume/103 ml/litre/106 0.001 mbar/bar.
Incidentally, for gas flow in pipes, at very low pressure where individual molecules are moving along the pipe, behaviour is different and it's called Knudsen flow.
10/06/2012 10:27 AM
GA Codemaster for understanding what I wanted to ask further. I was busy answering to Tarnado's comment before seeing your's.
Anonymous Poster (3); Codemaster (1); Joshi (2); PWSlack (2); Tornado (2)
