Previous in Forum: Requirement for a PE Stamp   Next in Forum: Skirt Support Design
Centrifugal P/P
10/07/2012 5:30 PM
is wear ring & casing ring in a centrifugal pump is same or different and how to check clearance and where to check if u can explain with some diagram it will be good for me to understand
thank you sir
Re: centrifugal p/p
10/07/2012 6:33 PM
It depends on the specific pump construction, but I think there are usually two such rings. The wear ring surrounds the impeller on the shaft side; the casing ring surrounds it on the suction side.
Re: Centrifugal P/P
10/07/2012 9:33 PM
Have you been to the pump manufacturer's web site?
I'm not sure what a Centrifugal P/P.
Register to Reply 2 comments
