Previous in Forum: Electric Boiler   Next in Forum: Submersible Pump
Electric Motor Shaft Tolerance
10/15/2012 8:29 PM
Hi All
Can somebody help me out of establishing a way of choosing a tolerance for motor shafts. I am currently looking in the AS1654.1 1995 standard. I understand the tolerance and calculations but it does not tell you how or why a specific tolerance grade is chosen. I also understand there are ranges for grades, however, choosing a grade seems to be a personal preference. Is this correct, would really love some help thanks in advance.
Re: Electric Motor Shaft Tolerance
10/15/2012 9:34 PM
Why do you think a particular tolerance is chosen? What factors do you think are related to the space between two parallel, rotating surfaces in a motor?
What is your experience level, then?
I don't know what you are really after, but if your plans including selecting and buying a motor, I'd take a motor person out to lunch.
Why would you need a special combination of shaft tolerances if you don't understand why tolerances are chosen in the first place.
Ask a motor supplier to help you, and tell him what you are doing, which you have not done here.
10/15/2012 9:41 PM
I understand why different tolerances are choosen eg general engineering, structures, production of semi products and am working in the motor industry. I know I have to choose a IT5 to IT12, there is nothing that says which particular grade to choose. It is a motor that is under repair with no OEM data other than a previous same motor was repaired with no given tolerances.
10/15/2012 9:51 PM
Does the motor have a nameplate?
10/16/2012 1:41 AM
I think the dimensions are already specified in motor manufacturer association standards such as NEMA. [?]
10/16/2012 9:11 AM
I think you are probably right. It's not worth the effort to check.
Looks like we have another "overthinker".
10/16/2012 10:45 PM
Tornado, Lyn
Thanks for your review, I have managed to get toloerances from SKF Catalogues. As I stated previously I have to go off an Australian Standard, and NO I am not over thinking but thanks for your concern.
Once again thanks for your efforts.
Register to Reply 6 comments
aurelioc (2); lyn (3); Tornado (1)
