Previous in Forum: Electric Motor Shaft Tolerance   Next in Forum: Power Line Tripping
Submersible Pump
10/16/2012 3:54 AM
We have a star delta control panel for controling five 7.5 kw motors but unfortunately the motor is submersible type and it is delta connected type. how can we connect this panel to the motor. Any new addition needed for this.
please help me to solve this problem
Re: submersible pump
10/16/2012 3:59 AM
The compartment for the motor that is delta-only needs to be redesigned and rebuilt as a direct-on-line starter. This is not a job for the uninformed, so the best thing to do is to contact a specialised local panel-builder that can come to site, do the drawings and carry out the alterations. Yellow Pages?
10/16/2012 6:22 AM
DOL, auto transformer or soft start are the solutions for 3 lead motors. star delta starters are used with 6 lead motors. but i am not sure about your system voltage .
Anonymous Poster #2
10/16/2012 7:04 AM
dear,
You will have to do few modifications in panel, so that motor can be run in direct on line. and if u want to reduce starting current then auto transformer or soft starter may be used.
Good Answers: 137
Re: Submersible Pump
10/17/2012 4:39 AM
You could remove the cover of the pump terminal box. If there are 6 terminals (connected in delta) you're in with a chance. Check out the cable needed for star/delta (probably 7 cores, including earth). If the existing cable gland will take the new cable, you're OK. Just possible there is a spare gland, blanked off. If so, it's easier, you can run a 2nd cable.
Obviously you need a star/delta starter, and wire it all up properly.
Anonymous Poster (1); arifkunnath (1); Codemaster (1); PWSlack (1)
