Previous in Forum: Literature About Metal Cracks   Next in Forum: What Do You Think
9 comments
Please Help Me How To Calculate MDMT
10/22/2012 11:14 AM
please help me how to calculate MDMT (minimum design metal temerature) for any material for costruction of pressure vessel so as to check impact test requirement.
this is harish
from mumbai
Re: please help me how to calculate MDMT
10/22/2012 11:28 AM
To what standard is this pressure vessel to be built?
Why metal and not something else?
Which metal?
Design temperature and pressure?
What wetting fluids?
this is PWSlack
from Dodman's Lane.
10/22/2012 11:56 AM
pressure vessel is built up with ASME Sec. VIII, Div. I
Metal is SA 516 Gr. 60 (Applicable to my case)
Design temp 50 Deg. Cel. & pressure 6 Kg/sq. centimeter (g)
wetting fluid is not given in data sheet
pls. help if possible
10/22/2012 12:00 PM
The wetting fluid is the stuff that the pressure vessel is being designed to contain; examples are water, compressed air, hydrogen, sulphuric acid, propane. Please state the fluid(s) in this case.
Good Answers: 34
10/22/2012 11:30 AM
Look HERE
10/22/2012 11:51 AM
hi joshi
by using u r link i reach up to explanation given by mR. abdel halim gala but at point no. 4 & 5 he has provided one link it is not working thats why i am not able to calculate MDMT pls. help me if you are having information
Good Answers: 34
10/22/2012 1:17 PM
Good Answers: 34
10/22/2012 1:31 PM
Some more HERE
Re: Please Help Me How To Calculate MDMT
10/22/2012 12:23 PM
Looking at this problem another way, the minimum ambient temperature for design purposes at this latitude could be selected as -20degC.
10/22/2012 10:50 PM
MDMT is not really calculated. Instead, it is looked up in tables of weather data (if climate is the source of low temperature) or chemical properties (e.g., pressure-temperature relationships that might give cold conditions). Then a suitable material for vessels, pipes, or structural components is chosen, again from tabulated data.
Register to Reply 9 comments
harish patil (2); Joshi (3); PWSlack (3); Tornado (1)
